Home > Maintenance & Mods (L322) > oh oh I thought of something else - Rear wiper washer..
Bus
I just remembered I had to ask this. It's a dumbass question so I'm sorry in advance, anyway the rear wiper washer doesn't work at the moment, it worked last week, just not now - when I need it.
I'm assuming the rear and front washers is supplied by the same reservoir, yes?
If so I think I may have a blockage - this is where the dumbass bit comes in - I can't find the rear jets, are they hidden away in a pain in the arse place to get to. Or, this being far more likely, am I being a Censored and I just can't see them?
Post #40088 29th Nov 2010 7:53pm
JustinP
They are part of the wiper arm, two small holes near the pivot.
I had mine unblocked last week at the dealers, the also cleaned out a one way valve in the pipe work and charged my £20 for the privilege.
Are you sure yours is not frozen?
Post #40102 29th Nov 2010 8:54pm
dan_uk_1984
They tend to freeze very easily and the pressure isnt great so it tends not to push the ice out of the nozzle. Also if you run without a winter mix of antifreeze in the washer the one way valve gets damaged from the ice expanding in it and can top letting water though in either direction.
Post #40105 29th Nov 2010 8:59pm
JustinP
And don't confuse coolant antifreeze with screen wash antifreeze as thats likely to bung-up the entire system or worst still damage your paint work!
Post #40111 29th Nov 2010 9:16pm
