Home > Technical (L322) > My first clonk/clunk!
RRR207
Switzerland 2005 Range Rover Autobiography 4.4 V8 Zambezi Silver
While driving the evening the car has developed a clonk on turning right.
I think it's coming from the passenger side front wheel but not 100% sure?
I'm guessing a bush or track rod end let go ????
Any other suggestions from people with experience of this sort of thing, it's my first L322 and I'm not used to all its foibles or idiosyncrasies yet!!! Current - RRV Autobiography 4.4V8 2005
Modifications - 20" Westminster Alloys with Grabber AT's. BRC LPG Conversion.
Previous- RRC 3.9V8/91. RRC 4.2V8/94 LSE Softdash. RRC 2.5tdi/94. RRC 2.5tdi/91. RR p38 2.5DHSE/01, Disco2 2.5td5/03, Disco4 2.7tdv6/10 ..... all gone.
Member of the RangeRoverRegister & Wessex4x4Response (Bristol Team)
Post #401513 21st Aug 2016 11:27pm
fisha
Most commonly the ball joints that attach to the lower part of the hub wear out and start clunking. There are a number of posts on here about replacing ball joints. Not hugely expensive parts, but can be a pain to do because the ball joints seize into place making them hard to get out.
It is a diy - able job if you're that way inclined. V8 or else ...
Post #401660 23rd Aug 2016 10:43am
RRR207
Thank you, I'll investigate Thumbs Up Current - RRV Autobiography 4.4V8 2005
Post #401806 24th Aug 2016 1:39pm
Jimmy C
United Kingdom 2003 Range Rover Vogue Td6 Zambezi Silver
Check drop links also Very Happy
Post #401915 25th Aug 2016 8:40am
