![]() | Home > Technical (L322) > coolant leaks and cylindre head |
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8715 ![]() ![]() ![]() |
Sounds very unlikely to me, take it to a second garage and ask for another opinion...
pepa80 Member Since: 20 Aug 2015 Location: Madrid Posts: 17 ![]() ![]() ![]() |
Hi.
doclees Member Since: 25 Jun 2015 Location: PA Posts: 672 ![]() ![]() ![]() |
I agree with Haylands. Find the leak. Can you smell coolant? It doesn't need to be BMW coolant but it does need to be OAT (dex-cool) coolant. As for head gasket repair there are products that work well. The exception is when the head gasket leak is between cylinders. |
Clivefog Member Since: 23 Aug 2015 Location: Bristol Posts: 354 ![]() ![]() ![]() |
Alloy heads can become porous. Any fracture in the head will seal up in use and open up once cooled. Pressure test should be on a cold engine.
Hi.
OK so you have loss of coolant that does not smell, does not produce any smoke. How is the oil? Any coolant in the oil? |
RR P38 Member Since: 12 Oct 2013 Location: Sydney Posts: 215 ![]() ![]() ![]() |
Small coolant leaks can be hard to identify if they are coming to atmosphere.
Hi everyone.
Weegie Member Since: 09 Jun 2014 Location: East Sussex Posts: 3268 ![]() ![]() ![]() |
Have you checked the filler cap? I would be inclined to try a new filler cap to eliminate that as a possibility before looking at potentially much more expensive solutions. There won't necessarily be any traces at the cap for a small loss.
Hi.
How much coolant is needed to fill after 600km? The fill cap has an "O" ring type gasket. The gasket gets old and leaks. Usually you can see coolant from this leak on the tank. Usually you can smell it. |
Hi,
That is quite a lot for those little miles. Plus you don't smell any. It only has 3 places it can go. 1. Out the cooling system which you should see or smell. 2. Into the oil which you should see. 3. Into the cylinders. Being a diesel, which I know very little about, maybe it is harder to see or smell at the tail pipe. Assuming it is a head gasket leak into the cylinder this sealant should fix it.
johnboyairey Member Since: 11 Jan 2013 Location: surrey Posts: 2035 ![]() ![]() ![]() |
Might I suggest, for a few days, remove the engine under tray, and with a clean floor, park up, and see if you get a drip or two to identify the area to look further at. Maybe go for a gentle drive, and park up. And idle for 10 mins. If it's collecting on the under tray, it might be dried by the next journey draft winds, and the next gathering drips, await the next drying journey. With a large sheet of flat cardboard, slid under, you don't even need hard concrete, if you have gravel drive etc.
