Home > In Car Electronics (L322) > I-Bus Message Help to Fool a DSP please
Zulu 10
I have successfully managed to install a new Erisin head unit in my MY04 L322, however, not satisfied with that I also wanted iPod integration in some form – ideally digitally.
Moreover I hoped to retain the DSP and original speakers (at least for the time being).
Consequently I have connected the S/PDIF output of a Pure i20 iPod dock directly to the co-ax digital audio input of my DSP.
I have written some Python code to generate I-Bus messages to initialise the DSP, set volume etc, and to generate spoof status requests and responses to/from the radio and nav units. (I’ve also used the code to update time and date at the dashboard, and display a personalised message, sad, eh?).
The software is currently on a laptop, but I'll transfer it to a Raspberry Pi with touchscreen once finished.
Anyway, all seems to work satisfactorily and I can command the DSP to use its digital input, change volume etc, which it does for approximately one minute, and sounds fine, and then it goes back to sleep. It generates no error messages or anything when it does so, but a bus re-initialisation recovers it without the need to recycle power.
I suspect that this one minute keep alive drop-out is due to my failure to generate a specific message which it expects to see on a regular basis, but of which I’m unaware.
I’ve tried generating Radio to CD Changer demand and response messages such that the bus contains typical traffic, but to no avail.
I’ve gone back through the NavCoder logs to try to identify the missing message but can’t find it.
Does anyone, I wonder, happen to have a bus definition that lists all the messages (possibly FF broadcast ones) which the DSP expects to see in order for it to maintain normal operation?
[edited to add: the same time out problem applies when connected to the analogue input as well, and I've measured it at 40 seconds rather than a minute]
Many thanks in advance.
Post #401796 24th Aug 2016 12:25pm
bebechoon
France
I don't even understand the question! What language is it in? Embarassed
Bus definitions? Is that a Bus timetable?
Python code. As in Monty ...??? Confused
I suppose this post will mean something to someone. I bow down very low before such experts Bow down !!! It's "bébéchoon", ackcherly, with accents. 'Steve' to my chums.
20 years ownership of Solihull products, ALL GONE NOW, sniff!
Current motor: Suzuki S-Cross 4WD auto, 1.4 petrol. Oh so reliable! 7 years now and no problems. Oh, all right then, a leaking shocker replaced under guarantee.
Previous:
TD6 HSE L322 Auto FF
2.5 TDi 4-door Classic
Disco II
And my 1st Rangie: in 1995, a 2-door VM 2.5 diesel Classic
Not to mention the Lada Niva before those. (I said not to mention it!)
Post #401823 24th Aug 2016 3:11pm
At last, Thumbs Up I knew it must be possible, like bebe I'm afraid it is way above my pay scale and I can't help with your request but well done for getting that far...
Is there someway to "read" the canbus code or do you have to know what it should be,,,??? Pete
Post #401833 24th Aug 2016 5:17pm
MrKev
Good job Zulu 10, but have you seen my post?
Yes, there's a keep alive message. See here for circuit, and source code on bitbucket. If you can update with any new
http://www.fullfatrr.com/forum/post349650.html#349650discoveries, please do!
It's worth keeping the DSP in if you can, the sound is much better.
@Pete: it's NOT canbus. That's something else.
Kevin[/u]
Post #401836 24th Aug 2016 5:31pm
Zulu 10
...er..both Pete:
I've bought one I-Bus to USB interface from a chap in Germany (Rolf Resler), and built a second less sophisticated one myself.
I use the simple one to feed a program called Navcoder which can capture all bus traffic for analysis.
I use the Gucci one connected to and generating messages created by my 'touchscreen'.
Hopfully by using two I can avoid drawing false conclusions.
So far I can't see any difference between my message structure and that generated when the original units were installed, but I'm sure I've missed something.
There's talk on the BMW I-Bus fora of a Tech Service Bulletin to install a filter that slows down the waking of the DSP until the Radio is fully awake, but I've cobbled a few bits to mimic this and behaviour is the same.
Maybe my timings are still awry and I just need to finesse the code.
Worst case is I either revert to standard to make some more logged measurements from the original LR/BMW system, but if I can find someone who has already fought their way through such problems, then there's probably a reward...
Post #401837 24th Aug 2016 5:35pm
Zulu 10
Kevin[/u]
Sorry, URL wasn't visible first time
Post #401838 24th Aug 2016 5:35pm
MrKev
Sorry, I forgot to include the link... now edited.
The keep alive message needs to be sent approx every minute. As there's no collision detection on the I-bus, I think I send it every 10 seconds just to be sure.
Kevin
Post #401839 24th Aug 2016 5:36pm
See, I know even less than I thought... Kevin you have mail... Thumbs Up Pete
Post #401840 24th Aug 2016 5:37pm
Zulu 10
Thanks Kevin,
I'm intrigued by that message, because it's not directed at the DSP (ID 6A), but I'll go and add a thread which, if I read your code right, is simply sending F0 03 68 01 9A every ten seconds.
My neighbours think I'm barking sitting on a garden chair on my driveway and gazing into the boot of my car...
The Gucci interface which I mentioned earlier contains collision detection, unlike my cobbled version.
Sadly that makes no difference - I tried generating the BMBT to DSP equivalent as well.
That said, it makes me think: I wonder if the DSP is expecting a Keep Alive Bit request from the CD player?
Post #401841 24th Aug 2016 5:46pm
Zulu 10, you have mail as well... Thumbs Up Pete
Post #401842 24th Aug 2016 5:48pm
gregdav
England 2005 Range Rover Vogue Td6 Bonatti Grey
Guys you all have, Bow down Bow down Bow down
way over my head.
but interesting.
Post #401854 24th Aug 2016 7:22pm
MrKev
Are you feeling audio into the radio box or straight into the DSP? Mine is feeding into the radio L/R and the radio makes front back left right signals to the DSP.
Kevin
Post #401855 24th Aug 2016 7:25pm
Zulu 10
Ah, now I understand why you've managed it, dare I say, so easily. Though I can't understand where your Case 1 Case 2 list is hidden.
In my case I've wired the new head unit's front speaker outputs into the differential analogue inputs to the DSP, and the iPod via a dock through a coax to the SMB socket on the DSP.
My follow-on is to use the Head Unit's line level outputs and feed them into a differential output op-amp, but I need to crawl before leaping.
The sound quality by staying at lossless digital all the way to the DSP is most impressive, so long as it will last for more than 40 seconds!
By using the input select bus commands I can happily switch between the two input - but after 40 seconds it goes silent.
Simply sending a Source = Off byte to the DSP, followed by DSP Initialise and finally Source = CD (iPod) is enough to get the DSP to re-start, then a volume +15, but obviously it's a major pain.
I think I have to examine carefully my handshakes.
As an aside I can set the clock and date, and set a 'my Range Rover' message to the display - happy to share the code if you wish, although I'm not a code monkey by trade, so it's rough and not well structured.
Post #401857 24th Aug 2016 7:39pm
MrKev
Yeah, code to set the clock would be cool. I could 'influence it' but most to 11.00 or 11.01 - interesting to see what I was doing wrong. I god bored of sitting in the drive with a laptop Wink
Dash messages could be good too, I'm sure I can think of something!
What about resetting the fuel consumption stats etc - any thoughts?
Kevin
Post #401861 24th Aug 2016 7:53pm
Zulu 10
To set the time
def buildtimemessage():
now = datetime.datetime.now()
t = now.time()
HbyteHour = hex(t.hour).lstrip("0x")
HbyteMinute = hex(t.minute).lstrip("0x")
byteHour = str(HbyteHour)
if int(HbyteHour, 16) < 0x0F:
byteHour = "0" + byteHour #for hour values in single digits, pad the string with a leading zero
byteMinute = str(HbyteMinute)
if int(HbyteMinute, 16) < 0x0F:
byteMinute = "0" + byteMinute #for minute values in single digits, pad the string with a leading zero
Post #401868 24th Aug 2016 8:22pm
