Home > Off Topic > TV question
TV question
Just bought 3 of these Wi-Fi enabled TV's .. 2 Samsung and an LG , question is when they are switched on and if any of the family are on their ipads , iphones , mac's etc they seem to cause a lot of interference through the TV's anyone know if this can be fixed , i have double checked all the cabling , splitter boxes and sockets to no avail ....
TIA for any advice 👍👍 ====================================
Post #402310 28th Aug 2016 12:26pm
mpirie
Does your router have dual frequencies?
The latest effort by BT has a 2.5Ghz and 5Ghz channel....it might be worth moving the devices to another frequency to see if it makes a difference?
Post #402380 29th Aug 2016 12:51am
Will check not sure as i am with sky broadband fibre ====================================
Post #402393 29th Aug 2016 9:32am
I have a billion Bipac 7800dxl router which has dual wifi and an EWAN port so it can be used with fibre services. So even if your sky one doesn't there are routers out there which will be sky compatible and give you the option of dual band wifi. Won't be really cheap solution though as the routers can be upwards of £100. There is nothing that can't be fixed with a hammer😜😜
Post #402468 29th Aug 2016 7:30pm
