Home > Maintenance & Mods (L322) > Hard reset
SFM
France 2012 Range Rover Vogue TDV8 Rimini Red
Hard reset
Hi all
Can some one tell me the correct way.to do a hard reset please?
Could not find it.in the wiki
Post #402547 30th Aug 2016 10:13am
battery disconnection ????
Post #402550 30th Aug 2016 10:26am
SFM
Cheers Stan
But I thought that there was a hard reset procedure, clears the engine ecu.
If I remember correctly, you have to touch the + & - connections together, but not sure of the correct method.
Can anyone.help
Post #402552 30th Aug 2016 10:37am
Rangeyman
If you'Google' hard reset there is lots of info there but are all on websites other than Fullfat so I cannot recommend any but the first one recommended disconnecting both battery leads and touching the leads together for 10 seconds before leaving 10 minutes before reconnection.Do your own homework before trying am not sure what it is supposed to do ,anyone elaborate ?
Post #402599 30th Aug 2016 2:12pm
Does depend what you are trying to reset, e.g. no form of battery disconnect will reset a hard fault on the EAS, you need a diagnostic tool for that Thumbs Up .
Post #402631 30th Aug 2016 4:56pm
abs66
I think what SFM is getting at is that the Hard Reset procedure mentioned on many posts is nowhere near as convoluted as the suggested wiki post item highlighted by Stan.
I was wondering about this myself, for example does the wiki procedure just apply to 2010 and later cars etc or can we still just connect the cables (obviously once clear of the battery terminals!) without disconnecting all the gubbins as stated on the wiki?
I'm not convinced i'm making myself clear here lol.
Post #544151 17th Feb 2020 5:17am
