|  | Home > Technical (L322) > Rear fog light trailer module |
| Bingy Member Since: 09 Feb 2015 Location: Colne Posts: 23      |
 Two years ago i fitted a tow bar with dedicated electrics for the two 7 pin plugs from PF Jones.
|  21st Aug 2016 3:43pm |
| Andy K Member Since: 06 Jun 2016 Location: GL Posts: 48      | Has your new tin tent got led rear lights ? | ||
|  21st Aug 2016 4:51pm |
| Bingy Member Since: 09 Feb 2015 Location: Colne Posts: 23      | No All Bulbs | ||
|  21st Aug 2016 5:02pm |
| mzplcg Member Since: 26 May 2010 Location: Warwickshire. England. The Commonwealth. Posts: 4029      | I had similar issues with the 13 pin to dual 7 pin adapter cable on a Disco 3. Nothing wrong with the cables, or teh car, or indeed the caravan. But the combination of all 3 led to lots of bonging and warnings about bulbs being out. I changed the loom on the car to a 13 pin one (not expensive and is plug and play) and it was all peaceful again.
|  21st Aug 2016 5:49pm |
| Bingy Member Since: 09 Feb 2015 Location: Colne Posts: 23      | Yes mine all worked fine on dual 7 pin plugs for 2 or so years.
|  21st Aug 2016 6:13pm |
 You can remove it if necessary. A 2 minute job. But this is likely to be fixed with the correct cable. Mine was. | ||
|  22nd Aug 2016 7:19am |
| Bingy Member Since: 09 Feb 2015 Location: Colne Posts: 23      | So i ripped out all the old twin sockets and wiring, together with the towing module.
|  30th Aug 2016 9:43pm |
| vaz Member Since: 15 Jun 2014 Location: Colne, Lancashire Posts: 332      | You can buy a converter that plugs in to the 13 pin socket and has a 7 pin socket for your trailer.
|  30th Aug 2016 10:34pm |
| Posting Rules
