![]() | Home > Maintenance & Mods (L322) > VIN service record |
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8751 ![]() ![]() ![]() |
Only at a dealer.
V8Noise Member Since: 25 Apr 2015 Location: Dereham Posts: 424 ![]() ![]() ![]() |
I'm guessing you are thinking about the supercharger coolant pump. As far as I'm aware, that's not subject to any recall. Of course it should be but, having had the reduced engine performance recently, I've done a bit of reading on the subject and found nothing to suggest JLR will take any responsibility for the problem. Brake hoses a different story. Give your VIN to your local dealer and he'll tell you if it's been done. 2017 5.0 Autobiography Supercharged 2005 Merc SL350 2005 Disco HSE 2.7 oil burner |
Mulcher Member Since: 08 Aug 2016 Location: Shropshire Posts: 240 ![]() ![]() ![]() |
Is this info only available from main dealers, or do the Indys have access to the JLR system? 2006MY 4.2 SC
As far as I'm aware, main dealer only. It's them that usually do any recall work because it's not charged. 2017 5.0 Autobiography Supercharged
Thanks 2006MY 4.2 SC
