![]() | Home > Technical (L322) > Rear centre vent repair |
UK Marine Member Since: 22 Jul 2016 Location: Durham, County Durham UK Posts: 835 ![]() ![]() ![]() |
Hi,
TimperleyRR Member Since: 13 Aug 2016 Location: Manchester Posts: 50 ![]() ![]() ![]() |
Actually there is only one unit. It is the one at the rear of the centre console supplying air to the rear passengers. |
Weegie Member Since: 09 Jun 2014 Location: East Sussex Posts: 3270 ![]() ![]() ![]() |
You seem to be describing them both as vent controls. The left one is the fan speed control and the right hand one opens both vents. Apologies if I have misunderstood.
Errm sorry I didn't spot that either doh.. ______________________________
Yes it is the left hand side one I am having trouble with. It is labelled as a fan speed control but in actual fact when you get it out it has 2 mechanisms. It mainly swivels a large baffle at the rear of the unit that impedes the flow off air (this is the lever mechanism I am referring to) then there is a microswitch that activates at the end of the travel. On the other side of the unit there is no visible mechanical attachments to the "hot/cold" button.
