Hi,
I’ve got a 2010 5.0L SC L322 with 43K on the clock. Recently on a long trip to the south of France with a fully loaded car the gearbox started to have a slight slip between 1500 and 2000 after 4-5 hours of driving, the second the RPM builds to over 2000 or it kicks down for a lower gear the problem goes away, this could happen at any speed between 1500 and 2000 RPM.
Has anyone had a similar problem? The gearbox oil is supposed to be good for 10 years. After a short stop at one point, less than 10 minutes of engine off, the problem went away, if it was heat or pressure related I would have still expected the same issue after that amount of time.
The car is going in for a service in a few weeks so I’ll ask them to check for fault codes but nothing comes up on the dash.
Thanks,
