Home > Technical (L322) > BMW Diagnostic Software for a Range Rover??
UK Marine
England 2003 Range Rover Vogue 4.4 V8 Zambezi Silver
Hi All,
I have a problem with my instrument pack, the problem is that it is beyond repair its something to do with circuit board tracks.
So I had two options,
1. Buy a new instrument pack.
2. Buy a used instrument pack.
I went the cheaper route (no surprises there) but if I just fit it I'll end up with the tamper dot and goodness knows what other problems I'll encounter. So I've been researching software that will read the old instrument pack and save the data, then erase whatever data is on the replacement instrument pack and write the data from the old instrument pack to the replacement and bobs your uncle, no tamper dot and the mileage and VIN are all correct.
The problem (or not ) is that it's software for BMWs. Maybe not such a problem seeing that my Range Rover L322 is mostly made up of BMW modules and ecu's.
I have an IIDtool but it can't do this, although to their immense credit the guys from GAP are going to have a go but they are a bit short handed and time is of the essence.
My question for the forum is has anyone tried the following software successfully on an L322,
SSS Progman
PA Soft 1.36 / 1.40
I've seen a demo of someone doing exactly what I need to do but on a BMW instrument cluster and it piqued my interest.
So please anyone out there with experience of this on an L322, any information you can give would be greatly appreciated.
Many regards ______________________________
Simon
Range Rover Classic 3.5 efi - Gone
Range Rover Classic 3.9 efi - Gone
Range Rover Classic 4.2 LSE - Sadly gone
Land Rover 110 3.5 - Gone
Range Rover P38a 4.0 SE - Pleased it's gone
Range Rover P38a 2.5 DHSE - Just sold
Range Rover L322 4.4 v8 Petrol - Current
Post #404567 13th Sep 2016 12:47am
Haven't heard of it done before on here...
If you manage it let us all know... Thumbs Up Thumbs Up Pete
-Click here for Thread-
Post #404605 13th Sep 2016 11:45am
UK Marine
I will. In my searches I've found quite a few of us owners of older l322s finding problems with their instrument packs with some of them unrepairable.
I know that these cars when new were £50k+ and that just because they are a few years old doesn't mean the prices of spares are going to drop, but that doesn't stop us from looking for a workaround.
It was quite interesting to watch the footage of the instrument pack being "replicated over, even though they mention eeprom soldering apparently it's not essential.
Regards to all ______________________________
Simon
Post #404612 13th Sep 2016 12:22pm
UK Marine
Hi,
Well I went ahead and bought PA Soft 1.40 and it works brilliantly.
I installed my replacement instrument cluster and the dreaded tamper dot was there, so I looked at the menu in PA Soft and found the section for the instrument cluster, one of the options was to write a VIN to the replacement cluster.
I'd noted the VIN from the Range Rover and entered the last seven characters as requested and the tamper dot disappeared..... Thumbs Up
The mileage on the replacement cluster was lower than mine so when I put the ignition on it showed the lower mileage. I read into this extensively and apparently the other modules that hold the mileage information only check with the cluster every 50 - 100 miles or so, depending on where you do your research I've even seen up 200 miles before a check is made. I'll obviously find out when I start to take the Range Rover out, and I'll report back.
When the check is made the mileage on the cluster should change to the mileage held in the other modules (LCM etc) but only if the mileage on the replacement cluster is lower than your original, if it's higher on the replacement then all of the modules holding mileage data will be updated to the higher mileage. Obviously not ideal so it's best to look for a lower mileage cluster. I've documented everything I've done with photos and kept the original cluster so I can show it to any prospective buyers in case they think I've tried to clock it, which was not the intention, my cluster was knackered.
As I've said the lower mileage should increment to the original mileage after a few trips, if not I'll keep all records especially the difference in mileage which is about 15000 miles.
You CANNOT change the mileage on the cluster not without taking an eeprom from the circuit board and rewriting it, like I said not ideal and quite a tricky and intricate task and not one that my 50 year old hands could manage...
The software itself is quite good insofar as it will interrogate all of the BMW based modules and read and reset faults, you can also change options and individualise your Range Rover, not as good or as easy to use as the brilliant IIDtool but you CAN remove the tamper dot from your cluster if that's what you need.
All in all a good result and the tamper dot was removed for the princely sum of £20 delivered...
I'll report back on the mileage in due course - fingers crossed.
Regards ______________________________
Simon
Post #405462 19th Sep 2016 8:31pm
Well done on that... a right result.... Thumbs Up Thumbs Up Pete
Post #405464 19th Sep 2016 8:37pm
UK Marine
I'm chuffed to say the least Very Happy
Simon
Post #405465 19th Sep 2016 8:43pm
desertdude
United Arab Emirates 2003 Range Rover Vogue 4.4 V8 Alaska White
Awesome! Any details as to which all modules it can talk to on the 1st Gen BMW L322s ?
Post #405486 19th Sep 2016 10:15pm
UK Marine
I'll hook it up in the morning and make a note of which modules.
I'll try and take some screen shots and upload them if possible. It's very comprehensive but dependent on having a laptop with you as opposed to the IIDtool which can just sit in the glovebox.
Simon
Post #405487 19th Sep 2016 10:19pm
desertdude
That will be totally cool and currently the only diag tool I have is an old ass OBD II reader which needs a laptop to run, so this will be an upgrade! lol
Post #405490 19th Sep 2016 10:51pm
UK Marine
From memory you'll be amazed at the amount of modules this thing will interrogate and customise.
Have a search on google for PA Soft 1.40 and BMW and enjoy..... ______________________________
Simon
Post #405492 19th Sep 2016 10:55pm
desertdude
I did but since very new to the L322 I really don't know what all made it across from BMW to the L322. And what is only specific to the L322.
Anyways waiting for further details and pics from you.
Post #405498 20th Sep 2016 12:23am
berkshirelad
United Kingdom 2007 Range Rover Vogue SE TDV8 Tonga Green
If it's anything like the LCM on the BMW/Rovers, then the max setting of the LCM is 150,000 miles - it doesn't update beyond that.
Post #405563 20th Sep 2016 3:15pm
UK Marine
Luckily the mileage held on my Range Rover is 146000, the new cluster has about 130000 so I should be ok - hopefully...... ______________________________
Simon
Post #405565 20th Sep 2016 3:18pm
