Home > Technical (L322) > Rear Parking Sensors
Not sure if its weather related but the rear parking sensors are going from silent to full constant beep in one action with the internal switch flashing?
Anybody had similar and know of a fix?
Post #40777 4th Dec 2010 10:50am
T24RES
Re: Rear Parking Sensors
I had a similar problem after i washed mine the other day. however without the flashing, a continuous tone. Cured itself after thawing out. With the pdc switched on with ignition in p2 (engine not running) if you put your ear next to each sensor they click like a dolphin if working correctly. Dud ones don't click and its a trip to the parts dept. Ian
Post #40783 4th Dec 2010 12:10pm
DavidP
Belgium 2006 Range Rover Vogue Td6 Bonatti Grey
Could need thawing out, I have this occassionally - now keep a pump-up bottle of screen wash by the front door and spray each one [bottle is really there for the wife]. Seems to work for me.
Post #40784 4th Dec 2010 12:13pm
might be ice on a sensor fooling it into thinking its up against an obstacle.. ... - .- -.
Post #40792 4th Dec 2010 1:07pm
PJS
Ive had this problem for a while, even before the snow, where the sensors on the back just beep randomly when I turn the ignition on and reverse. Not sure what the problem is.
Post #40811 4th Dec 2010 1:51pm
Stocky
United Kingdom 2019 Range Rover Autobiography 2.0 PHEV Fuji White
Mine does it sometimes, but it's only the exhaust gases blowing across the sensors and confusing them Smile Happens more when it's cold outside Wink
Post #40874 4th Dec 2010 10:11pm
Thanks for all the excellent replies will report back later as its warmed up a bit here!
Post #40897 5th Dec 2010 9:20am
