Home > Technical (L322) > 2003 TD6 whistle
Spelunker
England 2003 Range Rover Vogue Td6 Zambezi Silver
2003 TD6 whistle
Had a whistling noise like an old fashioned kettle the other day. It started when I pressed the remote unlock button to get in the car and seemed to be coming from the instrument cluster. The noise did not stop when I put the key in the ignition and started the big, noisy up and down - round and round lump under the bonnet or when I turned the blower on and off, but it stopped as soon as I pressed the brake pedal to put it in gear. It hasn't happened again, but any ideas anyone? QUID FACIUM TIBI
ANTEQUAM ALIIS
2003 TD6 VOGUE Zambezi Silver
tows 2006 Lunar Delta 540/2
Post #406229 24th Sep 2016 10:34pm
Roverlord
England 2003 Range Rover HSE Td6 Zambezi Silver
have a read here.
http://www.fullfatrr.com/forum/topic29209....+box+noise
and here
http://www.fullfatrr.com/forum/topic7953.h...+box+noise
and here
http://www.fullfatrr.com/forum/topic1811.h...+box+noise
Post #406488 26th Sep 2016 2:53pm
Spelunker
Doesnt seem to be any of these - it was a definite high pitch almost electrical sounding whistle which stopped dead as soon as I pressed the brake pedal. I will have a look/quick spray, but as it is very intermittent it could be some time before I know if it has worked. QUID FACIUM TIBI
ANTEQUAM ALIIS
Post #406516 26th Sep 2016 5:07pm
had a whistle on my old car which seemed to emanate from somewhere in the drivers footwell. this it was maybe something to do with a sounder or speaker capacitor as it only happened a couple of times in 3 years. There is nothing that can't be fixed with a hammer😜😜
Post #406534 26th Sep 2016 7:12pm
Only ever happened to me once many years ago and in my TD6 , the consensus has always been its an errant signal to one of the parking sounders possibly due to low voltage , not an indication of anything that has been proved serious. 2008 MY Supercharged
Post #406572 27th Sep 2016 1:40am
DeRanged Rover
United Kingdom 2006 Range Rover Vogue SE Td6 Java Black
Ive had that a few times too. It tends to fade away after a while. Nover could figure out what it was - the parking sensor issue above is most likely cause I suspect.
Just more electronic gizmodos ... African Bush Junkie ... in London!
Stats:
2006 TD6 Vogue SE
1972-2015 DeRanged Rover
2001 P38 dHSE (SOLD)
Post #406658 27th Sep 2016 6:02pm
