![]() | Home > Technical (L322) > Battery or Starter Motor |
nbunney Member Since: 10 Aug 2008 Location: Lancashire Posts: 2059 ![]() ![]() ![]() |
Very flat battery |
Sportex Member Since: 12 Jun 2010 Location: Up North Posts: 366 ![]() ![]() ![]() |
Don't use it unless your battery is 100%
well totally gone and died now, tried to jump, boost, new battery, but now absolutely lifeless |
Your battery can only be 2 years old so its not right if it is dead. I would get your alternator charge current checked at the same time as the new battery |
Agree in theory unless the battery has had a couple of deep discharges from things being left on etc. Most lead acid batteries are useless after 2 or 3 complete run downs as it knackers the plates... ![]() |
when it was trying to start, it was not one clicck, but tic tic tic tic tic, lights flashed and dashboard lights on off and dials twitched No body told me there would be days like these
GJOB Member Since: 24 Oct 2010 Location: Northants Posts: 131 ![]() ![]() |
That's definitely the sign of a dead battery ![]() |
ukrangie Member Since: 20 Jun 2009 Location: Kent Posts: 520 ![]() ![]() ![]() |
Perhaps get a multimeter from somewhere like Maplin to isolate the issue or call the AA/RAC to do it. You will want to check the battery and the current going into the starter motor.
Took some real juice to fire it up again, many tries and still seemed very reluctant, but up and running now, we see how it starts tomorrow No body told me there would be days like these
AAH Member Since: 18 Oct 2010 Location: London Posts: 13 ![]() ![]() ![]() |
had the exact same thing happen after the last cold snap when i was parked up at stansted airport for a few days. took a lot of tries to get it going and once started all the warning lights came up and the car would only give me 3rd gear. after 45mins of driving i had the courage to switch off and fortunately there was enough juice in the battery to restart and everything went back to normal. Been fine ever since. TDV8 Vogue 2006 (2007MY) Tonga/Black |
existing battery totally goosed, new one for £140 all sorted No body told me there would be days like these
