![]() | Home > Technical (L322) > .................................. |
RR P38 Member Since: 12 Oct 2013 Location: Sydney Posts: 215 ![]() ![]() ![]() |
Has the work shop used it before, on a FF?
Im just a bit suspicious of that label.
desertdude Member Since: 10 Sep 2016 Location: Dubai Posts: 60 ![]() ![]() ![]() |
Just because it is red (ish) doesnt mean its the wrong fluid spec.
If you have taken 7 litres out the thats pretty damn good. Was the trans over filled?
If you are doing another drain, if available you could drop some Dr tranny in, it works miracles.
Grab some of this stuff;
