![]() | Home > Technical (L322) > Message on instrument cluster |
That's normally associated with a battery low condition. The cranking drops the battery voltage low enough that some of the ECUs get confused. |
supershuttle Member Since: 20 Mar 2011 Location: Lancashire Posts: 3940 ![]() ![]() ![]() |
Probably means "special programmes off" - sorry couldn't resist.
GraemeC Member Since: 01 Jul 2012 Location: Chester Posts: 836 ![]() ![]() ![]() |
Happened on mine on start up when the battery was on the way out - probably best to get it checked and replaced in advance of winter if required (or of course it will let you down in the least convenient way possible....) 2007 Zermatt Silver TDV8 Vogue SE - now sold but was a great car! |
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8767 ![]() ![]() ![]() |
yep, check the battery and alternator before winter sets in, mine used to do that occasionally, normally nothing actually wrong with the drivetrain usually power related. |
