Home > Technical (L322) > Scan results
marcevs72
England 2003 Range Rover Vogue Td6 Adriatic Blue
Scan results
Have had few problems with my 2003 td6 and have scanned it and the live data @tickover shows 0rpm on all cylinders and injector readings of 0mm3 on all injectors.
Car has had new in tank pump,lp pump,fuel filter,all injectors tested and 4 replaced and recent full service.
It's now running slightly rough with bit of black smoke which gets worse when trying to drive car.has got me baffled now and any help from you guys would be much appreciated
Post #406537 26th Sep 2016 7:22pm
miggit
Have you checked the crank case breather? if it's still the old style filter they can be prone to getting blocked and causing smoke issues.
Other than that if your still getting the misfire I would suggest that you get a compression test done, as you seam to have covered all other possibilities Rolling Eyes Yesterday I couldn't spell Engineer... Today I are one!
Post #406618 27th Sep 2016 11:40am
Mikey
It's highly unlikely that ALL 6 cylinders are reading 0mm3
It sounds as though the diagnostic is not communicating properly with the PCM
Post #406696 27th Sep 2016 9:10pm
miggit
^^ 0rpm and 0mm3 on all cylinders Shocked should be 800 rpm for a kick off Thumbs Up Yesterday I couldn't spell Engineer... Today I are one!
Post #406719 27th Sep 2016 11:45pm
