![]() | Home > Technical (L322) > Headlight Igniter/ballast code |
Spelunker Member Since: 02 May 2016 Location: Nottinghamshire Posts: 248 ![]() ![]() ![]() |
Hi. Ive got the intermittent non starting off side headlight fault (its not the bulb) and having read the procedure for sorting it I am raring to get started. I have a 2003 td6 Vogue and can anyone tell me the part code(s) for the igniter/ballast unit?
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35837 ![]() ![]() |
you can get the part number off microcat [link in wiki] or i'd be tempted to buy a whole unit off ebay and use that or its parts.. ... - .- -.
Thanks for this - can anyone tell me if it is the ballast or igniter that is more likely to be the problem. I only have it when turning the light on - once it is on it stays on (until you turn it off of course)..... QUID FACIUM TIBI
ironhorse Member Since: 13 Dec 2013 Location: birmingham Posts: 355 ![]() ![]() ![]() |
sounds like the igniter to me(the black box with the two wires going to the bulb inside the headlamp unit) |
the igniter starts the light (black box inside the headlamp unit) |
Surely if it wont come on every time it is the igniter? QUID FACIUM TIBI
Yes yours is the igniter
andyboy Member Since: 24 Aug 2010 Location: south wales Posts: 540 ![]() ![]() ![]() |
Thanks Ironhorse |
