Home > Maintenance & Mods (L405) > L405 Tow Hitch
Page 5 of 6 <123456>
YMFB
England 2016 Range Rover Vogue SE SDV8 Causeway Grey
Any chance of a photo and the order details, now with the quote option selected, doh.
Post #562697 26th Jul 2020 12:14pm
YMFB
Phil. wrote:
Had PF Jones fit a detachable Westfalia tow bar on my 405 on my drive a couple of weeks ago. £770 inc. VAT. It’s great, easy to pop on and off. So is the cover underneath. No need to cut the cover unless you want to leave the tow bar on for an extended time. Works a treat with my Thule bike rack.
Any chance of a photo and the order details?
Post #562698 26th Jul 2020 12:15pm
YMFB
Was it this one ?
Post #562700 26th Jul 2020 12:22pm
That’s the one I’ve got. Thumbs Up
Albeit with dedicated wiring. There is nothing that can't be fixed with a hammer😜😜
Post #562701 26th Jul 2020 12:29pm
Phil.
Yes. The hitch is easy to remove and fits in boot under the cover by the spare tyre. The bumper mid-section cover takes seconds to remove/fit with a coin. Very pleased with it.
If you go with PF then choose the dedicated RR wiring kit because then the RR recognises when you are towing and all the electrics are aligned. MY23 D350 HSE
On my 7th RR plus various other JLR vehicles
Post #562702 26th Jul 2020 12:30pm
YMFB
£742.39 mobile fitted, booked with PF Jones.
Post #562707 26th Jul 2020 1:45pm
YMFB
Well sad to report PF Jones are either shut or not interested, I’ve tried e mailing and calling, which is what they suggest after you done the on line process. So I’m now looking for an alternative or getting Hendy to fit a detachable one.
Post #564057 9th Aug 2020 7:20pm
Phil.
Very disappointing. They were fine when I used them a couple of months ago both by mail and phone. MY23 D350 HSE
Post #564059 9th Aug 2020 8:27pm
YMFB
I’m very disappointed, I will give them one more go tomorrow then off somewhere else.
Post #564066 9th Aug 2020 9:44pm
cupples8267
Scotland 2016 Range Rover Vogue SE SDV8 Santorini Black
I have just fitted a westfalia detachable towbar. It took around 2 hours on my drive. The video from Powerful was useful in removing the bumper, although it is pertinent to be much more gentle removing the plastic trims. The towbar kit is very easy to install. the only part I modified slightly was the plastic bracket which holds the centre of the rear bumper tow panel- I slightly trimmed the centre of it to give clearance fir the towbar When the towbar swan neck is removed the bumper cover fits with no trimming required. Use a torque wrench and specified torque settings as screwing into an alu chassis. The dedicated tow electrics work fine with no programming required.
Post #566902 12th Sep 2020 10:03am
tomo141
I currently have a deployable tow bar on my MY13 which is going next week, My replacement MY18 (facelift) doesn't have a tow bar.
Is anyone able to tell me if the following will fit 2018. I have messaged the seller, however he stated it should, but i need to make sure. I have read on the forum that the frame is essential and don't buy if its not present as you can't buy them separately.
L460 D350 73 24 model FFRR Autobiography Santorini Black with Shadow Pack
L405 4.4 V8 18 FFRR Autobiography (facelift) Santorini Black with Shadow Pack
L405 3.0 V6 13.5 FFRR Autobiography Santorini Black
L322 4.4 V8 12 FFRR Autobiography Santorini Black (RR Styling Pack)
L322 3.6 V8 10 FFRR Autobiography Santorini Black
L322 3.6 V8 07 FFRR Vogue SE Santorini Black
L322 3.0 I6 55 FFRR Autobiography Santorini Black
Post #586608 7th Mar 2021 4:54pm
James W
Saudi Arabia 2017 Range Rover Autobiography SDV8 Siberian Silver
Has anybody tried one of the TowTrust detachable tow bars like this one?
https://www.ebay.co.uk/itm/Towbar-Detachab...3587874372
I had a TowTrust on my D4 and was very pleased with the quality. This looks to be pretty good value?
Post #591573 18th Apr 2021 7:25am
JST
England 2012 Range Rover Westminster 4.4 V8 Stornoway Grey
Does anyone have a tow bar fitted (fixed or detachable) with an SVO rear bumper fitted?
If so did you have it fitted and by whom or self fit?? What brand/model is it please? Cheers
James
Post #699796 8th Sep 2024 8:36pm
Mikeerhymes
United Kingdom 2011 Range Rover Vogue TDV8 Stornoway Grey
Hi Guys,
Just installed the Westfalia tow bar, nice easy job. However, I must be missing something as there is nowhere to now screw the 2x screws in the rear trim into. The instructions say to throw away the original threaded nut assembly, but nothing replaces this from what I can see. Any ideas?
Thanks
Post #700593 21st Sep 2024 7:46pm
Cav
Towbar quotes and which removeable swan neck?
Wasn't sure if I should start a new thread but questions on this thread are pretty variable so dont shoot a newbie!
Having just acquired an L405 without a towbar I am looking for quotes. PF Jones have a GDW that comes in at £789.10 with 13 pin electrics and mobile fitting. The Westfalia is £859.10 so in the scheme of running a FFRR not a lot more but is it better than the GDW?
Usage is occasional 750kg trailer (once a month max) and even more occasionally a 2000kg trailer.
No issue for me removing cover each time I want to use it.
Any other companies I should look at for mobile fitting or close to Herefordshire. So far my quotes range from £789.10 to £1400! Finding it hard to tell on some sites if coding is included or not - I guess not on most.
Thanks in advance
Post #707884 30th Dec 2024 6:44pm
