![]() | Home > Technical (L405) > Can you retrofit front fog lights ? |
XXXAngelXXX Member Since: 25 Mar 2007 Location: Stuttgart Posts: 4995 ![]() ![]() ![]() |
Without a headache ?
Doodle Member Since: 02 Nov 2013 Location: Midlands Posts: 127 ![]() ![]() |
Gutten morgen,
i found a new pair for 200 Euros in the UK.. All my spelling errorz are belong to me!
That's good value.
362bkr Member Since: 15 Oct 2014 Location: Devon Posts: 680 ![]() ![]() ![]() |
I nearly bought one without fogs and the dealer quoted £ 1200 to retrofit them . I didn't buy that car ............... |
I think the retrofit is expensive and not the parts... |
Alistair Member Since: 11 Feb 2011 Location: Peterborough / Bordeaux / Andorra Posts: 8105 ![]() ![]() ![]() |
Including the parts to switch them on ?
http://www.ebay.de/itm/Range-Rover-405-Ran...Sw0fhXkLw-
Nick Ground Member Since: 27 Dec 2011 Location: Dorset Posts: 584 ![]() ![]() ![]() |
Replacing a complete column switch will no doubt be very expensive! The dash graphic is free and the wiring loom is probably already there. Programming the CCF file?
I see - a costy headache... |
paulmoran2 Member Since: 27 Nov 2013 Location: Leeds Posts: 1422 ![]() ![]() ![]() |
Wouldn't you also need the front black plastic section that runs the full width to mount the fogs into also?
The German VSE seems to be a bit different - Frank has also changed his door handles nd front side vents to the same as the UK VSE spec
Useless perhaps, but i want the look of it - btw my car is fully loaded like an AB - weird the previous owner did not ordered the fog lights when new - FFS ! |
andy2577 Member Since: 04 Jun 2016 Location: Liverpool Posts: 64 ![]() ![]() ![]() |
You will need a new front bumper , front bumper wiring harness and a new switch
