Home > Technical (L322) > Front Anti Roll Bar Bushes
cliffy
2004 Range Rover Vogue 4.4 V8 Zambezi Silver
Guys
How hard is it to do the anti roll bar front bushes on a 2004?
Done all the other suspension stuff still getting a clunk there the only i aint done and given the movement in the upper and lower arms it only seems right to do the anti roll bar bushes to
thanks
neil
Post #408034 6th Oct 2016 10:50pm
miggit
Shocked Just had a look in Rave... and lets say that Land Rover have made it very hard.. that's not to say that you can't get at it, as the anti roll bar wouldn't need to be removed as you can cut the old bushes off and the new ones are split.... so in theory they should be replaceable with out removing the anti roll bar.
The bar is at the rear of the sub frame, if you can get at the caps and remove them in place all will be good... if you do the job the Rave way, you have to drop the rear of the subframe to gain access Shocked
I think it's rather amusing that Land Rover have started to produce split bushes... 2 years ago you could only get bonded to the anti roll bar ones and had to change the whole thing... looks like they have caught up with the after sales market Whistle Yesterday I couldn't spell Engineer... Today I are one!
Post #408042 7th Oct 2016 12:15am
