Home > General > 1 year on.
Clivefog
1 year on.
I've had the beast just over a year.
It came with various problems that got fixed under the sale - no dash indication of indicators/fog light front and back/gear selection, no infotainment screen, no reverse lights, no hooter - how did it get that brand new MoT?
Also pixels were covered, as was the alternator that died just before Xmas, still using the battery that appears fine.
Nothing else needed other than for peace of mind oil changes oh and gearbox filter. Ops for got exhaust weld on the cat but my son did that so no cost.
So as a birthday present I got the wheels powder coated and new tyres, booked it in for 4 wheel alignment and they have found worn bushing that they say will need to be fixed prior to doing the alignment, ok I say and today they had it in.
Just had a call to say the hand brake shoes lining has become unbonded, and the rear pads need replacing oh and the disc is beyond safe limit,. no extra labour sir as it had to come off anyway.
Digital TV and reversing camera put back in abeyance!
Post #408123 7th Oct 2016 1:54pm
mzplcg
No Hooter? Shocked Shocked Shocked
Made me smile, where I come from hooters are not related to parts on a car Rolling with laughter
That said, hooters can be used to give you a horn Thumbs Up
Post #408173 7th Oct 2016 7:10pm
Clivefog
Old English, none off this American horn business please.
Sadly they were doing the alignment and sheared off a bolt, replacement arrived but too late to do the alignment pick it up tomorrow. Must be worth a toot on the hooter!
Post #408212 7th Oct 2016 9:53pm
mzplcg
Old English? Or "Brizzle"? (from a bloke born at St Michaels, BS2) Laughing
And yes, any excuse for a toot on the hooter Thumbs Up
Post #408235 8th Oct 2016 7:22am
Clivefog
Got it back and well I don't think I have notice such a change in any other vehicle that I've had alignment adjusted.
Smile restored, bank balance a little less happy!
I'm a Souff Lundon boy!
Post #408321 8th Oct 2016 5:21pm
mzplcg
It does make such a difference to how they drive though. So many people don't realise because they drive nicely anyway, but they really are so much better when all the geometry is spot on.
Post #408322 8th Oct 2016 5:48pm
Hi Clivefog
All the issues you reported in your first post when you bought the car are very similar to the issues I have been having when it rains:
http://www.fullfatrr.com/forum/topic37575.html
Did your seller report on what they needed to do to fix it? Might give me some clues...
Thanks .
Post #408331 8th Oct 2016 7:10pm
Biffo
United Kingdom 2005 Range Rover Vogue Td6 Cairns Blue
Hello Clivefrog, where did you go for the 4 wheel alignment - was it an LR independent ? I wondered if they need to plug in and read the steering position and get it at zero before they set the geometry up. I need to sort mine out !
Post #408332 8th Oct 2016 7:18pm
There are quite a few garages which have the 4 wheel alignment systems nowadays. Even my local quick fit has one!!
The system you are looking for is a Hunter Hawkeye. They don't need to plug it in, the machine detects the centre.
Ideally you should have the car in tight tolerance mode on the suspension when doing it, but I have never had a problem just settling the suspension on a level car park first by raising it and putting it back into normal before it goes on the ramp. There is nothing that can't be fixed with a hammer😜😜
Post #408333 8th Oct 2016 7:29pm
Clivefog
Yes they did give me a list of bits changed and put it with the cars history, which was then "lost", I gave up asking if it was found. I do remember main light unit, in car screen and a wiper relay, although both front and rear worked fine. There was a load more sorry not to be of more help.
Hunters machine at Westerleigh Car Centre Downend Bristol. Happy with the work which they would not do without replacing a bush or two first, so I had a lot done.
Post #408369 8th Oct 2016 10:08pm
^^^ Thanks Smile .
Post #408479 9th Oct 2016 5:06pm
