![]() | Home > In Car Electronics (L322) > reversing camera fit |
littlecub Member Since: 02 Apr 2013 Location: Ulverstone,Tassie Posts: 327 ![]() ![]() ![]() |
Hi all,
bebechoon Member Since: 22 Apr 2014 Location: In ze middle of Frainsch nul part Posts: 455 ![]() ![]() |
The easiest is probably under the rear bumper, as long as you can get the 'angle of dangle' right. That’s where I put mine (not the same camera), and it works a treat. See my install post: http://www.fullfatrr.com/forum/topic34829.html (& in the Wiki).
ndg Member Since: 25 Mar 2016 Location: Warwickshire Posts: 94 ![]() ![]() ![]() |
Check the wiki, there's a thread in there on just this. |
mattyp Member Since: 30 Jul 2016 Location: Clacton On Sea, Essex Posts: 101 ![]() ![]() ![]() |
This is what I plan to do, just on the look out for a used handle |
mattyp: this is on French Fleabay:
Thanks guys for the helpful hints.
miggit Member Since: 12 Jul 2014 Location: Milton Keynes Posts: 3666 ![]() ![]() |
A handy tip.... if you get a BMW X5 camera... make sure it's an NTSC, there are a lot of PAL ones on the market now, and cut the plugs off the lead to thread it through the rubber tube in the tailgate.... this will save you no end of bother and when you come to wire them into the TV module you'll find that the plugs are not needed at all |
try this |
