![]() | Home > Maintenance & Mods (L322) > Engine Failsafe Mode Fault......... Fault...!!??! |
| Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8822
Went to see my Mother yesterday who has been in hospital all week, 500 mile round trip....
I think one of these:
Joe... sounds about right cheers... faulty sensor or Ecu I think, could be moisture somewhere as it hasn't been used in a while......
| RR P38 Member Since: 12 Oct 2013 Location: Sydney Posts: 215
I had all the issues you report last week, only I made it into limp home mode.
| Sandyt Member Since: 07 Nov 2013 Location: Wraysbury Windsor Posts: 2287
Pete I reckon the fault within a fault is a spider - its scared you are going to wash it away so it is hiding and getting some payback |
It's been fine now for several days, no bongs or lights on... It wasn't used for several days prior to this so I suspect moisture got into some plug or other and upset the sensitive little thing.... Ah bless.... Pete
| miggit Member Since: 12 Jul 2014 Location: Milton Keynes Posts: 3668
Pete, how old is your alternator? Might be a brushes thing. On the not so mighty Landcruiser that I had to drive for a living, when the alternator had a hicup the whole dash would light up with every error light know to man and some that weren't |
Read 4 lines up from the bottom on the first post.........!!!!!
Have you been in the wet stuff again? possible ingress in the ecu box under the bonnet? Or maybe it's just trying to say hello in a FF sort of way |
Been fine for 17 months and now, exactly the same thing...
| doclees Member Since: 25 Jun 2015 Location: PA Posts: 672
Other sites that mention this tend to point to electrical or LPG. I saw you said the LPG was spot on and the alternator was fairly new as the battery. So what about ground connection or a bad cell in the battery? Not in the RR but my triumph had a bad cell that took months to finally kill the battery. Read fine and charged fine but every now and then would act as if dead and then just fine again. |
I have a voltage gauge inside the FF, my first thought was low voltage but the volts were above 14 so don't think it was that...
I really know nothing about LPG systems for autos. I assume you fill the tank and not swap it out with another? Do the tanks have condensation issues over time? |
Separate pressurized gas tank in the spare wheel well... no issues with condensation as it's sealed, uses it's own injectors fitted into the inlet manifold, LPG ECU "steals" info from the FF's engine ECU re injector opening times, lambda feedback etc to control the mixture but if you get poor quality LPG it's like old petrol, the engine won't like it...
