![]() | Home > In Car Electronics (L322) > Nokia Hf kit |
rattly Member Since: 15 Oct 2016 Location: Cotswolds Posts: 45 ![]() ![]() ![]() |
Does anyone know which fuse/or how is dis-connect the Nokia Hands Free kit that is still in my RR, hoping its the cause of my battery drain, headlamp wipers work and sat nav is shutting off! |
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8815 ![]() ![]() ![]() |
I would imagine it depended on who fitted what Nokia kit... If you can't find it to remove it then it's probably best to go to an auto electrician... |
See here if like the one I had/have....
Hi Joe90...That`s the one, I`m not too worried about removal, just dis-connection for now, keep getting flat batteries if RR not used for 4/5 days! The blog mentioned fuse 22, do you think could I just remove this for now?
Just find the box of tricks under the dash and disconnect everything .
