Home > Technical (L322) > Strut sealing gasket
Stacker
United Kingdom 2003 Range Rover HSE Td6 Adriatic Blue
Can anyone shed some light on what this is used for? It goes between the shock absorber and chassis.
This plank here forgot to put it in when I put the New Delphi Strut in!
Cheers!
Post #409859 19th Oct 2016 6:46pm
This gasket is probably not vital in terms of operation, but is there to prevent metal to metal contact (especially if different metals are involved - electrolysis etc.) I reused the old ones when I changed my struts.
You should be able to get the gasket on without taking the whole thing apart again, support the hub, just undo the top nuts and lower the hub to create the clearance you need. .
Post #409872 19th Oct 2016 7:25pm
Stacker
I thought that might be the case in all honesty, I looked at it and realised a new one didn't come with the Delphi strut and told myself I will have to re use the old one, and still forgot and realised afterwards! Rolling with laughter
I think i'll just order two when I make the next Island 4 x 4 order, as it will be free shipping, at about £1.10 inc VAT each I might as well just use new!
Just a pain in the butt!!
Post #409889 19th Oct 2016 9:07pm
