Home > Technical (L322) > Can you identify this connector?
miggit
I'm trying to identify the make of this connector, so that I can get a plug that is the same...
It's 25 mm x 14 mm and the pins are approximately 3 mm wide
Whistle I'm looking to join on to the cable that plugs in to this, but without cutting anything :wink:
Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated Mr. Green  Yesterday I couldn't spell Engineer... Today I are one!
Post #410136 21st Oct 2016 4:48pm
Scotchlock ? (Starts flame war! Twisted Evil )
They all look a bit like this, but everyone I have had apart looks different in some way. Is there nothing in RAVE (Connections in Electrical Library) that helps? .
Post #410218 21st Oct 2016 10:22pm
miggit
Whistle Might not be 'ang''over related, but thought I'd sand a better chance near the top of the forum Wink Yesterday I couldn't spell Engineer... Today I are one!
Post #410221 21st Oct 2016 11:30pm
Martin
Site Admin
Looks similar to the VW part number 1J0 973 803
Have you got the other connect that fits with it? Any part numbers or markings on it?
Post #410222 21st Oct 2016 11:51pm
Martin
Site Admin
Actually scrap that VW part number, that's the 1.5mm wide tab version.
There is a 2.8mm wide tab version, but only as a plug, not the socket you've shown.
The plug is 1J0 973 723
Post #410223 21st Oct 2016 11:55pm
miggit
That was as far as I got.. I thought eureka when I stumbled on the VW plug... and then relised that it was a 1.5mm blade... I'll try and get some more info off the plug, but it's right at the back of the engine bay and buried under a load of fuel and cooler pipes Shocked Yesterday I couldn't spell Engineer... Today I are one!
Post #410226 22nd Oct 2016 1:05am
holidaychicken
What vehicle is it off and what is it connected to?
Post #410227 22nd Oct 2016 1:09am
miggit
Embarassed It's Mercedes ML 270 CDI swirl flap actuator..... I've just had to do a delete, but to fool the ECU and stop it going into limp mode you have to add to the circuit... at the moment it's just pushed in to the plug... but it's not a good fit. I'm not that worried about cutting the loom and joining in the patch.. but if it could be made plug and play... Whistle there could be a few quids to be made Whistle And it would be easily reversible too Thumbs Up
You lot don't realise just how lucky you are that Land Rover decided to use the non swirl flap motor from BMW... there are a total pain... because the inlet manifold is made by Airfix the moving flaps wear the holes down and cause no end of problems... and then it jambs and triggers limp mode Sad
Still having done the job I'd rather be changing injectors on a Rangie than remove the inlet manifold on a Merc.. they have bolted everything including the kitchen sink to it... fuel filter, fuel cooler, power steering reservoir, EGR cooler... and then you have to remove the fuel rail and thermostat to get enough clearance Clarence... total PITA Yesterday I couldn't spell Engineer... Today I are one!
Post #410243 22nd Oct 2016 9:47am
holidaychicken
It may be worth having a google for Bosch 3 pin connector and looking at images or mercedes 3 pin connector or bosch weatherproof connector but select images and try and find one that looks similar and then go to the page. That's how i found the connectors i needed for my sidelights.
https://www.google.co.uk/search?q=bosch+we...gC#imgrc=_
https://www.google.co.uk/search?q=bosch+3+...gC#imgrc=_
https://www.google.co.uk/search?q=mercedes...wQ_AUIBigB
Post #410266 22nd Oct 2016 3:02pm
miggit
Well after much faffing about (right at the back of engine bay, under windscreen, and coolant tank Evil or Very Mad )I discovered that the plug was made by Kostal Very Happy and it's restricted supply Sad and there is no plug Big Cry
Just about to give up and hack the loom, and stumbled on what looks to be the right plug on AliExpress (Ping Pong Fleabay copy, they'll copy anything Laughing ) Mr. Green But in true Chinese, don't give too much away, tradition there are no sizes, so I'm now waiting for a pigeon English reply Laughing Fingers crossed that I can understand it Wink Yesterday I couldn't spell Engineer... Today I are one!
Post #410511 24th Oct 2016 3:22pm
miggit
Well after a sort 3 week delay the plugs turned up..Perfect Mr. Green where would we be without Ping Pong's copyright laws Laughing Yesterday I couldn't spell Engineer... Today I are one!
Post #413924 16th Nov 2016 3:31pm
and all for £1.39 delivered .... Laughing ... - .- -.
Post #413927 16th Nov 2016 3:37pm
miggit
I wish, you need to move the decimal point to get nearer the price.... but at least it came in less than the VAT threshold, so HMRC didn't get to add their pain to it Laughing Yesterday I couldn't spell Engineer... Today I are one!
Post #413929 16th Nov 2016 3:41pm
