![]() | Home > Technical (L322) > Slight wine coming from gearbox |
p38arover Member Since: 16 Dec 2015 Location: Western Sydney Posts: 1583 ![]() ![]() |
Bottle it and call it "Chateau ZF"? ![]() 2003 L322 V8 Auto 2007 Yamaha XJR1300 Previous: 1983, 1986 RRC; 1995, 1996 P38A; 1995 Disco1; 1984 V8 County 110; Series IIA |
smiler289 Member Since: 11 May 2016 Location: matlock Posts: 124 ![]() ![]() |
Haha I will be sure to do that! I meant whine. It seams to do it when changing from 1st to 2nd and very slightly from 2nd to 3rd. Not heard it on the gears above that but then the vehicle is travelling faster and there's more noise to hide it if it is doing it. Seams to get better as car warms up. |
RRPhil Member Since: 22 Aug 2011 Location: Blackburn, Lancashire Posts: 1023 ![]() ![]() |
Certainly worth checking the fluid level in case it's a bit low and the pump is cavitating slightly when cold
Cheers. I did that over the weekend. Noise got better slightly but still there. One thing that must be said is that I changed the trans temp sensor a few months ago as it was faulty. Obviously that meant draining the transmission oil. What came out was cherry red. The stuff I was recommended to put in was honey coloured mobil 71141 I think. Now am wondering if this could be part of the problem?
