![]() | Home > In Car Electronics (L322) > battery drains down if car not use every couple of days |
BOBCUSSEN Member Since: 25 Nov 2012 Location: DORDOGNE Posts: 296 ![]() ![]() ![]() |
HI folks
paulmoran2 Member Since: 27 Nov 2013 Location: Leeds Posts: 1422 ![]() ![]() ![]() |
http://www.fullfatrr.com/forum/topic781.ht...eplacement GONE 2010 Facelifted 3.6 TDV8 - Stornoway Grey + 22" Overfinch Olympus
thanks for the link paul, strange that Dan is saying it is access from the passenger side, where as simon from powerful.co.uk mentions taking the side panel off next to the pedals and is a 10min job, ?
I did mine from the drivers side on my UK car. Not sure if the FSR is in a different position if the steering wheel is on the "wrong" side. |
sounds a bit awkward being a blind job,? its bad enough if i can see what im doing never alone not |
miggit Member Since: 12 Jul 2014 Location: Milton Keynes Posts: 3661 ![]() ![]() |
thanks for the suggestions i will try the fuse first and see what occurs; i have checked the boot and seems ok;
Does the small red led next to the gear selector go off after about 15minutes or stay on permanently.
hi
georgedb Member Since: 12 Apr 2015 Location: Gauteng Posts: 82 ![]() ![]() ![]() |
[quote="nicedayforit"]Does the small red led next to the gear selector go off after about 15minutes or stay on permanently.
^ It means one of the 30+ ecu's hasn't switched off when the ignition key was removed and as such there will be a current drain which may be significant or not.
jon3929 Member Since: 01 Jan 2015 Location: Weston Super Mare Posts: 62 ![]() ![]() ![]() |
Would be worth confirming what your battery leakage rate actually is - is a very simple test. I have a similar issue but not quite so bad. I measured the battery drain current earlier today at 0.19 amps which is ok - think my issue is just a dodgy battery. There is another thread on here where someone measured 0.7 amps which would flatten it quite quickly.
Alistair Member Since: 11 Feb 2011 Location: Peterborough / Bordeaux / Andorra Posts: 8059 ![]() ![]() ![]() |
I would have thought 0.19 to be on the high side - I'm far from an expert but would expect below 0.1
holidaychicken Member Since: 06 Nov 2013 Location: Kent Posts: 1086 ![]() ![]() ![]() |
Headlight wiper arms not parking correctly can also cause a battery drain on the earlier models
