Home > Technical (L322) > Suspension calibration - tool ?
Biffo
United Kingdom 2005 Range Rover Vogue Td6 Cairns Blue
Is there a simple/cheap tool I can buy to set the suspension heights on my 2005 TD6 Vogue ? I understand that functionality is included on the IID Bluetooth tool, but I already shelled out on a decent diagnostic tool earlier in the year to cover my other cars, and that will read and clear everything for the RRFF, but just won't alter the suspension heights.
Also, is it best to check and adjust the suspension heights, then get 4 wheel alignment done ?
Post #411552 31st Oct 2016 10:34am
there's this from the GAP chaps Pete,
https://www.gap-diagnostic.com/shop/eascontrol/
Post #411553 31st Oct 2016 10:39am
Stacker
United Kingdom 2003 Range Rover HSE Td6 Adriatic Blue
That won't work will or Stan?
It's only to raise and lower if you get stuck somewhere if I remember correctly
Post #411555 31st Oct 2016 11:19am
no, it can adjust heights ,
Post #411556 31st Oct 2016 11:23am
Biffo
That looks perfect !
One height sensor was replaced before I bought it, nothing to say it was recalibrated. Another is reading 32v when stationary, whist the others are 1.2v/1.3v so I assume I will have some suspension joy to come and might as well be prepared.
Post #411557 31st Oct 2016 11:26am
Stacker
My bad, when I emailed them I was told I had to buy the more expensive one for calibration! You learn something new every day!
Post #411558 31st Oct 2016 11:34am
You can do it for the price of two metal coat hangers... I did it when I first got mine to raise it a bit, remove the plastic arms that clip onto the height sensors and replace them with metal ones, just a rod with a loop at each end, you can adjust the length to get the FF spot on at whatever height you like......
In fact mine are still on there as they are much stronger than the plastic and rubber arms, although i use the IID to do the work now... Thumbs Up Thumbs Up Pete
Post #411564 31st Oct 2016 12:06pm
