Home > Maintenance & Mods (L322) > PEL000070
Biffo
United Kingdom 2005 Range Rover Vogue Td6 Cairns Blue
PEL000070
I've read a few things in the Wiki about replacing the EGR thermal sensor valve, and was wondering about the compatibility of parts.
The Land Rover part is PEL000070, but I see reference to using a BMW part instead no part number quoted). Looking on line, the BMW part is under half the price of the Land Rover item Shocked but is it the same ? The BMW part number seems to be 11717787870 for any of the 3.0l BMW straight 6 engines.
Thanks
Post #412114 4th Nov 2016 4:22pm
gregdav
England 2005 Range Rover Vogue Td6 Bonatti Grey
Fitted one this morning, part number for bmw on mine was 11712247723, and yes, they are half the price of lr.
if you remove the cover in front of the rad, you should be able to read the part number.
about £20 or their about. Order one with the o'ring.
greg.
Post #412117 4th Nov 2016 4:38pm
Biffo
Thumbs Up Thanks !
Post #412118 4th Nov 2016 4:44pm
Weegie
@gregdav
On another thread there is a reference to the LR hoses being push fit where the BMW one uses jubilee clips. Which does that p/n result in, please? John
GAP iiD BT-Sold
Post #412121 4th Nov 2016 4:59pm
gregdav
Hi john mine were push fit, with those wire clips.
quite an easy job, there's a little hose above the rear bolt head, I had to undo this to access bolt, and re crimp after fitment, then top up with coolent. Checked later this afternoon, and everything is ok.
the part I believe is exactly the same as lr, as it has the bmw number on it anyway.
Greg. Thumbs Up
Post #412133 4th Nov 2016 6:42pm
Weegie
Greg, Many thanks. Looking at changing my thermostat and wanted to be sure. Thumbs Up
One further question, what manufacturer's one did you get? John
GAP iiD BT-Sold
Post #412135 4th Nov 2016 6:50pm
gregdav
Hi John, it was the bahr hella manufacturer.
Post #412164 4th Nov 2016 8:14pm
Weegie
Thanks, Greg Thumbs Up John
GAP iiD BT-Sold
Post #412167 4th Nov 2016 8:29pm
umitbat
A Trap 2010 Range Rover HSE TDV8 Atacama Sand
Is there a bmw number for PEL000050??
Post #415986 30th Nov 2016 2:14pm
gregdav
Haven't found one for the thermostat, but quite cheap anyway at island 4x4.
Post #416045 30th Nov 2016 8:28pm
I recently fitted this - was an easy job and works just fine.
http://www.ebay.co.uk/itm/222286162252
Gives these numbers: -
1171 2 247 723 - EGR Thermostat
11 53 2 248 435 - O-Ring
Post #416046 30th Nov 2016 8:29pm
wayneg
When I did mine I just went for the cheapest I could find on ebay. When fitting I realised I had got the wrong one, i did not know the BMW has a different fitting. Anyway the bit the hose goes on can be removed and swapped over easily so I would still get the cheapest I could find regardless of hose fitting and just swap it. 2007 TDV8 VSE
2003 TD6 gone.
2002 P38a gone
1999 P38a gone
1997 p38a gone
1993 VSE gone
1992 VSE gone
Post #416123 1st Dec 2016 8:01am
