Home > Maintenance & Mods (L322) > Shocker
ScubaChamp
Scotland 2011 Range Rover Autobiography 4.4 V8 Stornoway Grey
Shocker
Fellow FF owners,
I would be very grateful for your input. Bow down
I have a leaking rear shock absorber (the piston, not the bag) on my 2012 L322 and the shock needs to be replaced. I've been told by a colleague, who is a former BMW/VAG technician, that these should be changed as a pair to avoid potential handling/tyre wear issues. I bought the car Approved Used from a dealer (Grange of Welwyn) only in January, so it's still under the 2-year LR warranty. I've put it in to the local dealership in Aberdeen (Peter Vardy JLR), but they're saying they will only change under warranty the one that's leaking. They're suggesting that if I want them both changed, then one would have to be at my expense.
I'm yet to receive a quote for the work. However, I understand the part alone is around £400 if bought through the dealers!
An alternative option is for me to source Bilsteins or Monroes (£165 or £84 inc.VAT and discount, from Eurocarparts) and have my trusted indy garage do the fitting. Neutral
Q. Has anyone had a similar experience with replacing shocks under warranty? What was the resolution?
Q. To what extent is it the case that handling/tyre wear could be adversely affected if the shocks are not changed as a pair?
Q. Does LR warranty really not provide for replacement of these as a pair? And is it worth going to battle with them on this? Does anyone have an inside line that can confirm the situation?
Q. What experience do you have with Bilstein / Monroe shocks as replacements? From a quick bit of googling, I get the sense that the Bilsteins are top notch. Can anyone recommend the Monroes?
Many thanks in advance for any & all advice! Thumbs Up
Post #413149 11th Nov 2016 11:17pm
They are sealed gas filled dampers, theoretically they should be as effective at 20 years old as they are at one as long as they don't leak..
It is good practice to change suspension components in pairs but not essential, your failed one has failed prematurely and as such I would say you will be fine.....
I'd certainly rather have genuine ones fitted even if one is a bit older than the other...
I dare say I'm in the minority.... Rolling Eyes Pete
-Click here for Thread-
Post #413154 11th Nov 2016 11:55pm
ScubaChamp
Thanks Haylands,
Fair point! I can see your logic there. I've asked the dealers to reconsider, but we'll see what they say.
I had a sort of similar situation some years ago with Peter Vardy BMW, having to replace a sticking caliper + disc + pads under warranty, but of course they wouldn't stretch to replacing the disc + pads on the other side - I had to pay for those.
I didn't think to fight them on it back then, but it certainly was a kick in the Censored
Post #413156 12th Nov 2016 12:15am
Certainly worth an argument, you never know, they may pay for two... Thumbs Up Pete
Post #413159 12th Nov 2016 12:44am
I have the same thing on mine, but it hasn't gone in yet, going in on thurs.
I had a similar issue on the front shock/strut when the airbag sprang a leak, LR warranty will only pay for the failed component. So I just had the one swapped. Absolutely no difference in handling or driving characteristics at all.
Worth a try but tbh I wouldn't worry too much. If the other fails in warranty you can have that replaced then! There is nothing that can't be fixed with a hammer😜😜
Post #413168 12th Nov 2016 8:53am
IanV8
Scotland 2011 Range Rover Vogue SE TDV8 Santorini Black
I had one replaced under warranty and have not noticed any difference.
Are the other shockers you are looking at dynamic ones or ordinary gas shockers? That could be why there is a big price difference.
Ian
Post #413171 12th Nov 2016 9:48am
like a pair of gloves or shoes you'd think that both would be replaced but if only one is faulty then i cant see why they would pay to replace a strut that is ok.. Neutral ... - .- -.
Post #413172 12th Nov 2016 9:49am
miggit
^^ wot he says Thumbs Up
The only thing that I can add is as long as the rubber components is ok then I can't see any difference... different matter if the rubber is starting to go Evil or Very Mad Yesterday I couldn't spell Engineer... Today I are one!
Post #413177 12th Nov 2016 10:06am
Update.
Wasn't deemed bad enough to warrant replacing yet on mine and to check it again in 6 months (will still be in warranty) there was also a squeak from the belts when cold, only slight, but again deemed not bad enough to generate a claim as they would probably say no. I'm thinking tensioner and belt need doing but there's no rush. There is nothing that can't be fixed with a hammer😜😜
Post #414124 17th Nov 2016 6:39pm
