Home > Technical (L322) > sensor data readings
UK Marine
England 2003 Range Rover Vogue 4.4 V8 Zambezi Silver
There are numerous vacuum pipes for this engine, I wonder if you've maybe disturbed one?
Didn't you say that you were going to take off the air intake pipe from the air filter to the engine? There is a small vacuum pipe there that you might have disturbed, and this might be affecting your idle.
Regards ______________________________
Simon
Range Rover Classic 3.5 efi - Gone
Range Rover Classic 3.9 efi - Gone
Range Rover Classic 4.2 LSE - Sadly gone
Land Rover 110 3.5 - Gone
Range Rover P38a 4.0 SE - Pleased it's gone
Range Rover P38a 2.5 DHSE - Just sold
Range Rover L322 4.4 v8 Petrol - Current
Post #413805 15th Nov 2016 7:53pm
alistairh
I'm going to double check them all..i ended up simply checking the maf sensor..pete put me right before I tried spraying carb cleaner into the inlet and I ended up using my diagnostic instead to check sensors Thumbs Up
Post #413809 15th Nov 2016 7:58pm
UK Marine
Oh aye, best to listen to Pete he has a wealth of knowledge and best of all he likes to share it... Thumbs Up
Simon
Post #413811 15th Nov 2016 8:01pm
alistairh
Defo Thumbs Up Thanks for your input..
Post #413821 15th Nov 2016 8:22pm
alistairh
New battery fitted early doors...cars behaving a lot better..lights not dimming every time the revs drop and my idles perfect? Fingers crossed its fixed...taking the fatty fir a nice wee jaunt Down the borders from Edinburgh to blow the cobwebs off...cheers gents
Post #414190 18th Nov 2016 8:37am
