Home > In Car Electronics (L322) > Front park sensor not working. Audible but not sensing
phillips321
United Kingdom 2003 Range Rover HSE Td6 Galway Green
Hi guys,
My nearside front 2 parking sensors don't seem to be working properly
They both make audible clicks but they don't seem to pick anything up.
I guess the first thing to do would be to swap them around with confirmed working sensors to identify if it's the sensor or the loom.
Any idea how to get them out? 2003 TD6
If the fault doesn't follow the sensor then I will need to check the loom. Where does the other end terminate and how can I get to it?
Thanks
Post #413456 14th Nov 2016 9:01am
Zebedee
United Kingdom 2013 Range Rover Vogue SDV8 Santorini Black
They remove quite easily from the rear of the bumper, though you might have to remove the bumper to get to them.
Ebay has them from about £6.50 each. Current:
- 2017 L405 3.0 V6 Autobiography
Sold:
- 2013 L405 4.4 TDV8 Vogue
- 2004 L322 4.4 Vogue (BRC LPG)
- 2002 L322 4.4 HSE (having fixed timing chain guides)
- 2000 P38 4.6 Vogue (BRC LPG)
- 1981 2-door In-Vogue
- 1980 Ex-Army SIII LWB
- 1976 SIII LWB
- 1968 SIIA
Stripped for parts:
- 2003 L322 4.4 Vogue
Post #413460 14th Nov 2016 9:37am
miggit
If your really careful it is possible to pop them out with a small screwdriver...although this is NOT the recommended way of doing things.. It don't half save some time Wink
The correct method is to get behind them and push.... some can be done with the bumper in place.. but most require removal Sad Yesterday I couldn't spell Engineer... Today I are one!
Post #413464 14th Nov 2016 10:00am
Zebedee
Pictures of how they fit can be found here:
www.fullfatrr.com/forum/topic40357.html Current:
Sold:
- 1976 SIII LWB
- 1968 SIIA
Stripped for parts:
Post #413894 16th Nov 2016 11:52am
