Home > For Sale & Wanted > [Wanted] Detachable towbar
Jammer600
2009 Range Rover Vogue TDV8 Buckingham Blue
As above I'm after a swan neck type tow bar with key etc ideally, part no 323062[/s] 2018 Suzuki Jimny 2003 written off
2016 Range Rover TDV8 MY10 current
2013 Range Rover TD6 2005
2012 Defender TDCI 2007
2010 Toyota Hilux 2003
2009 Audi TT 1.8T 225
2007 Suzuki SJ 413 with 1600 fitted
2006 Yamaha R6 2000 still have this
2006 Audi A3 1.8T 1999
2006 Defender TD5 1998
2005 Audi A3 1.6 1998
2004 Suzuki vitara 1994
2002 Proton 1500tripple valve 1991
Post #414137 17th Nov 2016 7:40pm
Mistercorn
United Kingdom 2010 Range Rover Autobiography 4.4 V8 Java Black
Do you just need the removable part, or the whole lot?
MC
Post #414154 17th Nov 2016 9:37pm
Jammer600
The removable part
Cheers 2018 Suzuki Jimny 2003 written off
Post #414155 17th Nov 2016 9:39pm
Mistercorn
Is this the right one?
MC
Post #414180 18th Nov 2016 7:03am
wealy
United Kingdom 2014 Range Rover Vogue SDV8 Luxor
I have the farmers type if needs be.
Post #414189 18th Nov 2016 9:14am
Jammer600
It does look like the type yes
I know their are two different part numbers but I'm unsure if they have them on them, does anyone know?
Thanks 2018 Suzuki Jimny 2003 written off
Post #414310 18th Nov 2016 11:35pm
miggit
This what the detachable tow bar looks like........
The bit with the red top is upside down.. and is bolted to the underside of the car, looks like this...
 Yesterday I couldn't spell Engineer... Today I are one!
Post #414316 18th Nov 2016 11:55pm
Jammer600
Yes, it's the parts which go in the boot/actual detach which I need? 2018 Suzuki Jimny 2003 written off
Post #414387 19th Nov 2016 6:13pm
miggit
This is the only thing that I can see that looks right.........
http://www.ebay.co.uk/itm/RANGE-ROVER-VOGU...SwLF1X5mQX
But, I would check... that part isn't available separately, so it'll be a S/H unit... You might be able to a new one, try PF Jones, they sell the receiver on it's own so there is a chance that you can get the neck Thumbs Up Yesterday I couldn't spell Engineer... Today I are one!
Post #414390 19th Nov 2016 6:25pm
Mistercorn
That looks to be the same as the one I have. Mine came from a 2007 TDV8.
MC
Post #414617 21st Nov 2016 9:30am
miggit
As far as I know there aren't any differences with the removable parts of the towbar, it's the subframe part that's bolted to the car that differs.... something to do with the way the exhausts mount...
Mistercorn, not sure if your showing us what it should look like, or your offering the part cos it's no longer required..... Yesterday I couldn't spell Engineer... Today I are one!
Post #414658 21st Nov 2016 4:30pm
Jammer600
It seems these are the two numbers??
323062
323039 2018 Suzuki Jimny 2003 written off
Post #414865 22nd Nov 2016 11:18pm
miggit
Yes they are BUT you can only buy them together, OR you can buy the socket on it's own...I HAVE NOT SEEN the towball part offered by it's self other than second hand. You will need to contact Westfalia or a Westfalia dealer (PF Jones) to find out if you can just buy the towball part.
And I'm assuming that you have looked under the rear of the car to confirm that the towbar armature is present and that the socket is bolted in place.... if you have the electrics then you'll have the armature as they bolt to that. Yesterday I couldn't spell Engineer... Today I are one!
Post #414875 23rd Nov 2016 12:23am
what miggit said.
all the swan necks are the same, so if you find one it will fit, if you have the receiver have you checked that the swan neck isn't in the cubby in the boot? There is nothing that can't be fixed with a hammer😜😜
Post #414876 23rd Nov 2016 12:35am
Reecy
2003 Range Rover Vogue 4.4 V8 Santorini Black
Towbar
Jammer
Did you get fixed up
I have a full tow ar for the L322 armature, swan neck, boot box etc but excluding the wiring
Get in touch if it's of use to you
Reecy
Post #419396 23rd Dec 2016 11:58pm
