Home > Maintenance & Mods (L322) > Checking the engine oil level when cold/filling 4.4 TDV8
As those of you with a 4.4 TDV8 will know there is only an electronic dipstick.
This is a bit daft when filling from cold as it won't let you take a reading until the car has sat for 10 mins, and gives a false reading when the engine isn't warm.
there is a way to force the system to give you a reading when the engine oil level not available message is displayed. This will help when filling so the engine isn't overfilled.
its dead easy.
Edit: open the bonnet......
Navigate to the service menu in the cluster.
press OK
select oil level check
press OK
if message not available is displayed press the cruise control cancel button twice within 2 seconds.
this will take you out of the service menu.
Navigate back to the oil level screen and you should see the current level displayed.
top up to below the max level as when warm you will get a higher reading. then start and run the engine for 10 mins and allow to stabilise for 10. check again and top up if needed.
turn ign. off
allow to stabilise for 10 mins if you topped up.
turn the ign. on, hold the cruise cancel button for more than 2 sec.
turn ign off.
turn ign on. and check oil level on the display is registering.
Not tried it yet, but just read it and thought it could be useful...... There is nothing that can't be fixed with a hammer😜😜
Last edited by northernmonkeyjones on 23rd Jan 2017 12:27am. Edited 1 time in total
Post #414431 19th Nov 2016 10:14pm
160dmb
United Kingdom 2014 Range Rover Vogue SE SDV8 Santorini Black
Nice trick! 2016 (L405) Autobiography in Black with Ivory - for ULEZ
2014 (L405) VSE in Black with Ivory
2011 (L322) VSE in Black with Ivory
2005 (3.2 V6) Porsche Cayenne in Black with Savanna
1999 (P38) VSE in Burgundy (?) with Sand
Post #414451 19th Nov 2016 11:10pm
missed the first step out, tried this on mine and it didn't work.
I think it only works if the Bonnet is open. Thumbs Up There is nothing that can't be fixed with a hammer😜😜
Post #417624 12th Dec 2016 7:02pm
Rambles
April 1st
Bit early....but good one
To think you might catch quite a few with that one.
Bonnet up, trouser leg rolled up, hazards on, ....
Post #417670 13th Dec 2016 12:06am
Damn rumbled....... Laughing
But seriously it only works with the bonnet open. It's in the destructions...... There is nothing that can't be fixed with a hammer😜😜
Post #417687 13th Dec 2016 8:39am
