Home > Technical (L322) > Wiper speed relay
RRBlue
England 2005 Range Rover Vogue SE 4.2 SC V8 Buckingham Blue
Wiper speed relay
The IID tool threw up the following code last night:
0x4B Wiper speed relay: open circuit
As a result I have been hunting through the various manuals and relay boxes for the 'Wiper Speed Relay' and have found plenty of references to the Wiper Replay. Is this the same thing?
My wipers work perfectly except that when I select the high speed option on the steering column switch, the speed does not change from the normal setting.
Any guidance would be much appreciated. 2014 5.0 Supercharged Autobiography & 2015 3.0SDV6 HSE Lux Discovery 4
2005 4.2 Supercharged Vogue SE & 2011 3.0SDV6 HSE Discovery 4
2002 4.4 Vogue
2000 4.6 Vogue
2010 Freelander 2 TD4 HSE
2009 Freelander 2 TD4.e 2009
1992 Mercedes 300D
1986 Renault 2.1 Turbo D
1976 Morris Marina 1.8
Post #414609 21st Nov 2016 7:43am
alistairh
I had the very same issue last week..does your rain sensor work? If not try unplugging it..my wiper function returned to normal after doing so..mines was simply a knackered fuse in the end...
Post #414615 21st Nov 2016 8:48am
Andy K
United Kingdom 2005 Range Rover HSE Supercharged Rimini Red
There should be 2 wiper relays. These relays tend to look different to others and they have 5 pins
Obviously one needs replacing as the coil is open circuit.
Post #415126 24th Nov 2016 1:48pm
RRBlue
I finally got round to replacing the front wiper relay (the one behind the battery) and still get the same error code. Each time I clear the code it reappears immediately.
I have also checked the rain sensor and replaced the fuse. This made no difference. In fact I got the same error code with or without the fuse which suggests a problem perhaps with the module.
Guidance would be very welcome. 2014 5.0 Supercharged Autobiography & 2015 3.0SDV6 HSE Lux Discovery 4
2002 4.4 Vogue
2000 4.6 Vogue
1992 Mercedes 300D
Post #502137 19th Jan 2019 6:30pm
