Home > Maintenance & Mods (L322) > rounded /stripped torx
alistairh
Trying to remove my wing mirror and after getting access to the back of the assembly I've noticed someone's rounded off 2 of the torx heads...impossible to get it off now and I would be grateful for any tips on getting them out..thanks
Post #414985 23rd Nov 2016 7:33pm
UK Marine
England 2003 Range Rover Vogue 4.4 V8 Zambezi Silver
Not knowing what kind of access you have as I haven't done mine yet, I would look at using a dremel or such to cut a slot in and use a large screwdriver.
Regards ______________________________
Simon
Range Rover Classic 3.5 efi - Gone
Range Rover Classic 3.9 efi - Gone
Range Rover Classic 4.2 LSE - Sadly gone
Land Rover 110 3.5 - Gone
Range Rover P38a 4.0 SE - Pleased it's gone
Range Rover P38a 2.5 DHSE - Just sold
Range Rover L322 4.4 v8 Petrol - Current
Post #414988 23rd Nov 2016 7:39pm
RRV78
England 2003 Range Rover Vogue 4.4 V8 Java Black
Sadly I had the same issue and my only option was molegrips however the threads were so heavily corroded they snapped off.
Post #414991 23rd Nov 2016 7:45pm
alistairh
I will try the moleys first and keep my fingers crossed, mines are badly corroded as well....ive not got a dremmel in my toolkit yet so if that fails there's my excuse to purchase one Laughing
Post #414994 23rd Nov 2016 7:52pm
Have you soaked it in WD or other penetrating oil first ?
Post #414995 23rd Nov 2016 7:54pm
alistairh
Yeah sprayed wd40 on it a couple of times in the past 24 hours hoping it would help..it didn't Banging Head
Post #414999 23rd Nov 2016 8:02pm
UK Marine
It wouldn't, contrary to popular belief WD40 isn't a penetrating fluid and is actually hygroscopic, it actually attracts moisture.
I religiously use duck oil from swarfega, it is a true penetrating fluid and is non conductive nor hygroscopic, give it a try I'm positive you won't go back to WD40. ______________________________
Simon
Post #415009 23rd Nov 2016 8:33pm
Lukie
2002 Range Rover Vogue 4.4 V8 Zambezi Silver
I use an oil from the poundshop it used to be called DP90 not sure of it's name now (got about 20 cans on the shelf) it's amazing stuff I did a little serch on it and the DP90 got great reviews much better than WD40
I did think WD40 = Water Dispersal 40 blend
Post #415010 23rd Nov 2016 8:45pm
espaceboy
drill it then use an easy-out screw extractor. they are a set of 5 conical bits with a course reverse thread
you will not be able to reuse the screw though
Post #415011 23rd Nov 2016 8:56pm
alistairh
Thanks guys..shall have a read up and source 1 of them before I attempt to get the torx heads out..there is a tiny bit of grip left in the rounded heads so I'm hoping one of your recommendations gives it some movement...
Post #415012 23rd Nov 2016 9:00pm
miggit
Hammer in a hex bit? It might get a better purchase... failing that a cobalt drill bit Thumbs Up Yesterday I couldn't spell Engineer... Today I are one!
Post #415030 23rd Nov 2016 10:01pm
Hmb
England 2006 Range Rover Supercharged 4.2 SC V8 Cairns Blue
50/50 mix acetone atf 2010 Overfinch 3.6 V8 FFRR gone yee haa
2005 Supercharged 4.2 V8 FFRR (written off)
2007 RRSport v8 3.6
1996 300tdi Disco 1
Post #415038 23rd Nov 2016 11:10pm
alistairh
I've been scooshing torx heads all day with penetrating spray..hoped it would loosen things up..eventually tried to hammer in a hex bit and hoped for the best..never worked..looks like its a drill job at the weekend..only wanted mirrors off to restore bubbled backing plate..was going to get then repowdercoated tomorrow Banging Head
On another note..if anybody's had their doorcards off then tried to refit them..is there a trick getting the bit black trim back on that runs along the bottom of the window? Do you reattach to door then refit or attach to bottom of window and clip card to it? Its beaten me tonight lol..have to reorder more pop clip thingies as well as last jokers damaged the top row of them...im away for a beer Whistle
Post #415186 24th Nov 2016 7:53pm
