Home > In Car Electronics (L322) > Aux port upgrade
Simran0211
United Kingdom 2011 Range Rover Autobiography 4.4 V8 Santorini Black
Aux port upgrade
Hi guys first of all am sorry if this has already been covered.
I have a 54 vogue with the MOST entertainment system and would like to add a Aux port for music if it possible to get the wiring loom of an later model and intergrate them together if so what loom do I need and does the head unit need a software upgrade. Thanks in advance 👍 Bow down
Post #411703 1st Nov 2016 3:45pm
jon3929
United Kingdom 2005 Range Rover Vogue Td6 Zambezi Silver
I'm trying to work out how to do the same thing mate - let me know if you figure it out....
Cheers, Jon.
Post #415759 28th Nov 2016 11:05pm
Which one is MOST - I get confused - is that the BMW electronics ?
If so, then it's straightforward - not always cheap - but straightforward.
Post #415760 28th Nov 2016 11:08pm
jon3929
As far as I'm aware MOST is the fibre optic system that came in MY05 ish - not sure if its of BMW heritage or not.
Cheers Jon.
Post #415762 28th Nov 2016 11:16pm
Sounds like the Ford system then
Sorry - no Idea - mine of that era had RSE which came with an Aux in, so I had no reason to play
Post #415763 28th Nov 2016 11:18pm
Ajay(UK)
United Kingdom 2015 Range Rover Autobiography SDV8 Indus Silver
Your best option for the MOST system with the Touchscreen is to fit the Auxiliary Connectivity Module (ACM). Dan at Duckworths has them at a more realistic price than the RRP Whistle
http://www.fullfatrr.com/forum/topic40270.html
I have just fitted this to my 2006MY FFRR and it works great Cool
A word of warning.........even though it is "plug & play" their is a little more installation work for 2005/2006 models, thats models with the touch screen but not the 2007MY with the revised dash/glove box.
The head unit on the 05/06 models is located behind the touchscreen which means the top of the dash has to come off Shocked you also have to get creative with the location of the ACM control module behind the glovebox as there is very little room and the recommended location for Aux input/usb unit itself doesn't work with the earlier glovebox design Rolling Eyes
Here's where I mounted mine:
Although the user manual states using a maximum 4gb memory stick I am testing a 32gb one, it does struggle to read everything but in random mode its definitely playing all the tracks Wink
As well as the aux input you also benefit from the iPod lead which I understand will charge too but I have yet to test that. The system emulates the CD buttons and you cannot scroll through folder lists as you can on the newer models but all in all a very worth while upgrade Thumbs Up
Although it should only take a couple of hours to install allow yourself a day just in case or longer if everything goes wrong like it did for me Big Cry
Andy. 22MY Defender 110 D250 HSE X Dynamic, Gondwana Stone.
SWMBO: 2022 RRS D300 Autobiography, Firenze Red.
Gone:2015 L405 SDV8 Autobiography, Indus Silver with Black Pack.
Gone: 2014 Discovery 4 HSE Luxury Firenze Red
Gone: 2006MY Java Black TD6 Autobiography
Gone: 2013 Jaguar XKR Convertible, Italian Racing Red with Ivory Seats
Gone: 2010MY Stornoway Grey TDV8 Vogue SE with RSE
Gone: 2008 Disco 3 HSE, Hybrid Tv + Retro-fit RSE System & DVD
Post #415814 29th Nov 2016 3:11pm
do you not have an 3.5mm aux port already in the rear of the centre cubby? I thought all the most equipped cars had this? There is nothing that can't be fixed with a hammer😜😜
Post #415842 29th Nov 2016 6:44pm
Weegie
The earlier ones definitely didn't have it. I put in a system I got from Germany. Did a write up. Not sure when the aux port as standard came in. John
GAP iiD BT-Sold
Post #415856 29th Nov 2016 7:18pm
Simran0211
Many thanks
Brilliant thanks very much I am just waiting for Father Christmas to turn up with a 💷 Notes so I can get the nessary parts will keep you updated 👍
Post #416062 30th Nov 2016 9:56pm
