Home > Maintenance & Mods (L322) > Condensation on inside of rear lens
kin
England 2006 Range Rover Vogue TDV8 Zermatt Silver
Tried to do a search on condensation, but nothing, pretty sure someone mentioned it Confused
It didn't bothered me before until today, when I stood at a distance,I notice the ns looked brand new, but the os looked like its 10yr old !!!
I find my os rear light seem to have permanent condensation on the inside, is it possible to dismantle it and clean it? If its not possible, may be I should take my dremel and drill a number of tiny holes to help ventilate it and stop condensations....what do you guys think?
Post #2692 31st Jan 2009 5:23pm
Vigneron
United States 2008 Range Rover Vogue Supercharged Java Black
The rear light assembly is vented. That is how the condensation got there in the first place. Those of us living in wet climates have it worse.
Drilling holes will only exacerbate the issue. If the condensation does not burn off after driving then you should ask the dealer to replace. This is a known issue w/ FFRR. The heat generated by the rear lights should take care of the problem. If not get new ones as did I. 08 FFRR
Java Black/Sand
Post #2697 31st Jan 2009 7:20pm
kin
Thanks Thumbs Up Do you think this is a warranty issue? My other rear lens is perfect...
Post #2698 31st Jan 2009 7:31pm
Vigneron
mine was covered under warranty. 08 FFRR
Java Black/Sand
Post #2700 31st Jan 2009 7:34pm
Those without warranty are stuffed, like me.
When you come to sell the car, use a hairdryer to warm the lense and dry out the condensation! Discovery 4 HSE
1998 90 TUL FFR Hard Top XD Wolf
1993 90 Tdi
*Gone: L405 4.4 VSE, L462 D5 HSE LUX, L663 Defender 110 HSE, Discovery 3 HSE, 2014MY Range Rover Sport 5.0 Supercharged AB Dynamic; L405 Exec Vogue SE 4.4, 5.0 Supercharged Autobiography, Defender TDCi XS CSW, Defender TD5 HT, Vogue SE TDV8, Vogue TD6, RRSport SC 4.2V8, Classic 3.9 Vogue Auto, Land Rover Series 3 SWB
Post #2723 2nd Feb 2009 4:14pm
Blue Yonder
United Kingdom 2003 Range Rover Vogue SE Td6 Monte Carlo Blue
I had this take the lens out dry out perfectly infront of a heater overnight make sure bone dry inside and run a thin bead of silicon around where the lens joins the lamp body. Let dry, refit done. Thumbs Up Monte carlo Blue, Ivory Leather, 22 Khan Reps, 3.0 td6 Vogue
Post #4642 7th Apr 2009 2:45pm
kin
Mine was replaced under warranty.. Thumbs Up
Post #4645 7th Apr 2009 3:35pm
And when you remove the light you'll no doubt snap the pathetic plastic clip that secures it, and your dealer won;t sell you a new one on it's own! Big Cry Discovery 4 HSE
1993 90 Tdi
Post #4652 7th Apr 2009 4:14pm
Blue Yonder
it is an annoying fault when you think how many other cars at a snip of the cost of a rangie dont have this problem. Mad Monte carlo Blue, Ivory Leather, 22 Khan Reps, 3.0 td6 Vogue
Post #4658 7th Apr 2009 5:29pm
dantheman
Agreed - seems to be a common problem (?)... Will they not admit fault and rectify this? You should not have to take a hairdrier to them - or remove and reseal with silicon sealant...
These are supposed to be top end cars FFS Evil or Very Mad
Post #4662 7th Apr 2009 6:29pm
Just look on this as one of the unique idiosyncracies of Range Rover ownership Discovery 4 HSE
1993 90 Tdi
Post #4669 7th Apr 2009 7:23pm
