Home > Technical (L322) > Aux belt change 4.4 v8
RRV78
England 2003 Range Rover Vogue 4.4 V8 Java Black
I noticed a squeak today while pulling away on a couple of occasions.
I checked the belts and the air con belt doesn't look great so want to change them both.
As I've just got home and it's to dark to get a good look I'm hoping someone has a how to for changing both belts?
Post #444402 12th Jul 2017 10:13pm
alistairh
Post #444408 12th Jul 2017 10:45pm
Clivefog
United Kingdom 2003 Range Rover Vogue 4.4 V8 Java Black
You will need the fan spanner about £5. I tried to do it with the rad in place but had to give up and remove it.
Are you sure the squeak is the belt or could it be an idler or tension pulley?
Post #444428 13th Jul 2017 7:00am
RRV78
Thanks for the video.
The squeak could be the tensioner but will take belt off and check.
Luckily I have the spanner in the tool box from my p38 days.
Post #444430 13th Jul 2017 7:54am
ohuntsman
United Kingdom 2002 Range Rover Vogue 4.4 V8 Zambezi Silver
Just changed my belt and tensioner after the tensioner failed, Have LOADS of squeaking - if you manage to get rid of it I'd love to know how you did!!!
Post #444448 13th Jul 2017 11:21am
