Home > Maintenance & Mods (L322) > TD6 2003 - What antifreeze?
mrblonde
United Kingdom 2003 Range Rover Vogue Td6 Adriatic Blue
What antifreeze do i need for my 2003 TD6 please guys? Has it got to be from JLR or can I get it from any motor spares place?
Thanks all
Post #416447 3rd Dec 2016 3:09pm
RS2000CUSTOM
United Kingdom 2009 Range Rover Autobiography 5.0 SC V8 Santorini Black
Doesnt have to be this exact make but it is this type
 2009 - L322 5.0 S/C Autobiography
Post #416477 3rd Dec 2016 7:15pm
From RAVE
Anti-freeze
Use only ethylene glycol based anti-freeze (containing no methanol) with only Organic Acid Technology (OAT) corrosion inhibitors, to protect the cooling system
CAUTION: No other anti-freeze should be used with anti-freeze containing OAT corrosion inhibitors.
Thumbs Up Thumbs Up Pete
Post #416485 3rd Dec 2016 7:32pm
Weegie
Just bought 5 litres genuine to do the job. If you do a search on PDA500310 (5 litres) you will get some idea of prices (PDA500300 is the 1 litre size). John
GAP iiD BT-Sold
Post #416488 3rd Dec 2016 7:43pm
RS2000CUSTOM
From my L322 2003 TD6 owners manual
Coolant Specification
Use ONLY a 50% mix of water and Texaco AFC coolant. If this is unavailable, use only ethylene glycol based anti-freeze (containing no methanol) with only Silicate based non-phosphate corrosion inhibitors .
Whistle 2009 - L322 5.0 S/C Autobiography
Post #416493 3rd Dec 2016 8:17pm
UK Marine
England 2003 Range Rover Vogue 4.4 V8 Zambezi Silver
I was always told that OAT antifreeze was for 2006 on models and for everything before that it's ethylene glycol based but containing no methanol and has to have silicate based non phosphate corrosion inhibitors.
Pete is bang on that you must not mix different types of antifreeze though, so when flushing you must do so thoroughly maybe 3 or 4 times with fresh water. When refilling mix your antifreeze with de-ionised water as this stops any build up of scale.
Regards ______________________________
Simon
Range Rover Classic 3.5 efi - Gone
Range Rover Classic 3.9 efi - Gone
Range Rover Classic 4.2 LSE - Sadly gone
Land Rover 110 3.5 - Gone
Range Rover P38a 4.0 SE - Pleased it's gone
Range Rover P38a 2.5 DHSE - Just sold
Range Rover L322 4.4 v8 Petrol - Current
Post #416497 3rd Dec 2016 8:41pm
The quote from Rave is for the pre 2006 FF...
Rolling Eyes Rolling Eyes Pete
Post #416527 4th Dec 2016 12:02am
Weegie
http://www.fullfatrr.com/wiki/Recommended_Lubricants
Includes coolant. John
GAP iiD BT-Sold
Post #416542 4th Dec 2016 9:52am
UK Marine
I think the problem is that rave differs from the handbook, they both contradict each other Big Cry ______________________________
Simon
Post #416555 4th Dec 2016 1:27pm
Mine (TD6) had the pink stuff (OAT) when I got it 8 years ago so been using that since, not had any issues.... .
Post #416557 4th Dec 2016 2:01pm
RS2000CUSTOM
Whatever type we all use if changed at least once every 2 years it shouldnt matter anyway Thumbs Up 2009 - L322 5.0 S/C Autobiography
Post #416568 4th Dec 2016 2:57pm
builder1966
England 2004 Range Rover Vogue Td6 Adriatic Blue
rs 2000 totally agree but I have all my motors serviced at main dealers and you have to ask them to change had an argument with beadles to get them to do this year on my 2004 was done by lookers after asking 3 years ago lot to be said for servicing yourself if you have time for sure
Post #416582 4th Dec 2016 4:24pm
