Home > Technical (L322) > Intermittent lumpy idle and smoking, and also fbh issues
jonnyboy54321
So, for those of a nervous disposition:-
Talk about a relief - that's the left side one. Right was a newish one so fine too. Really can't say what a relief that was.
Theres a lot of cleanup to do here on the left intake assembly (?) so any suggestions most welcome.
Thumbs Up 2007 Vogue TDV8 with 255/55/20's fitted
Post #418901 20th Dec 2016 10:15pm
miggit
Mr Muscle Oven Cleaner worked very well on my Mercedes EGR and also freed off the variable vanes in my pals VW turbo... it takes a while, but it shifts the carbon in the end Thumbs Up Yesterday I couldn't spell Engineer... Today I are one!
Post #418931 21st Dec 2016 12:39am
jonnyboy54321
The happiest pre-Xmas sight. Been meaning to post but the festivities (and sleep!) got in the way.
Couldn't clean up the inlet as no.1 injector was stuck solid, so had to abandon which I wasn't happy about. But timing was useless.
Back to the snarling malevolent beast that a TDV8 is.
Sweet as a nut, seems like coolant level has stabilised, and chucked a Varta 020 on there while the plenum was out (made it a lot easier).
Moral of the story is - when you think you've got an injector fault you may not have one.
Now to sort out why the FBH aint working...
Happy Xmas and New Year all. 2007 Vogue TDV8 with 255/55/20's fitted
Post #420327 31st Dec 2016 10:30am
andygts
Was it the EGR then? Current
2017 Range Rover Sport SVR
2001 Porsche 911 Turbo
_____________________________________
Previous
2013 Range Rover Autobiography SDV8
2007 Range Rover Vogue SE TDV8
2002 Range Rover HSE TD6
+ Many other non LR products
Post #420343 31st Dec 2016 2:01pm
jonnyboy54321
It was indeed Andy.
At least i presume it was seeing as replacing them sorted it. Good call! 2007 Vogue TDV8 with 255/55/20's fitted
Post #420370 31st Dec 2016 4:28pm
