Home > Technical (L322) > Drivers door mirror
Benner91
United Kingdom 2007 Range Rover SE TDV8 Java Black
Drivers door mirror
Range Rover 2007 vogue se-----My cable going from the door handle to the lock snapped -- I replaced cable all working again -- my problem is now the drivers side mirror doesn't work I can't adjust from switch --- the power fold is still working -- I removed door card again and checked all wiring all seems good
Another issue is that when I started car and reversed the parking sensors are not working I don't know if this is a coincidence or a related fault
When I put my ear to them none of them are clicking (as I have replaced a front 1 a few years ago with this method)
When I disconnect the rear loom from the pdc module all the front ones make a clicking sound but when I plug it back in all sensors are silent
Thanks in advance for soloutions
Post #417786 13th Dec 2016 9:28pm
UK Marine
England 2003 Range Rover Vogue 4.4 V8 Zambezi Silver
Have you done a battery disconnect and ECU reset?
It's usually best to if you're experiencing problems with your electronics, especially after working on the car.
Best of luck.. ______________________________
Simon
Range Rover Classic 3.5 efi - Gone
Range Rover Classic 3.9 efi - Gone
Range Rover Classic 4.2 LSE - Sadly gone
Land Rover 110 3.5 - Gone
Range Rover P38a 4.0 SE - Pleased it's gone
Range Rover P38a 2.5 DHSE - Just sold
Range Rover L322 4.4 v8 Petrol - Current
Post #417787 13th Dec 2016 9:35pm
Benner91
How do you do a ecu reset
Could you recommend a good land rover diagnostic tool
Thanks
Post #417791 13th Dec 2016 10:01pm
UK Marine
Normally disconnect both the battery negative and positive cables after waiting the prescribed time (in the wiki), then wait a good 10 minutes then touch the two cables together for about a minute.
The IIDtool from GAP is about the only diagnostic tool anyone on this forum will recommend. I have the Bluetooth version and it's brilliant, you can do loads of things the dealers can do and possibly more.
They are sponsors of this forum and another sponsor Duckworths sell them, contact Dan from Duckworths for a price. They aren't cheap but they are worth it.
Best of luck. ______________________________
Simon
Post #417794 13th Dec 2016 10:07pm
Benner91
Brilliant
Thanks I'll do that now
Post #417800 13th Dec 2016 10:29pm
gregdav
England 2005 Range Rover Vogue Td6 Bonatti Grey
Check and recheck your connectors if you removed the door card. Loads of peeps had the same, it's a case of making sure the connectors are pushed fully in.
+1 for the iid tool, excellent piece of kit.
Post #417831 14th Dec 2016 5:39am
RRV78
England 2003 Range Rover Vogue 4.4 V8 Java Black
I went through exactly the same with my passenger side mirror when doing the cable. After having the door card off several times I found I had to remove the grey retaining clip off the mirrors multi plug and push it in firmly and all worked fine and still does.
Post #417933 14th Dec 2016 10:28pm
