Home > Maintenance & Mods (L322) > Help! No reversing lights
160dmb
United Kingdom 2014 Range Rover Vogue SE SDV8 Santorini Black
Hi all, as per the title post I have no reversing lights at all.
Some time ago I fitted LED lamps and I know they worked at the time, but now nothing.
I started checking things at the tailgate.
Disconnected the multi plugs that feed each of the reversing lights - no power there.
Went to the fuse board in the passenger glovebox - checked and replaced fuse 12 (5A) - which looked ok.
I now get a feed at both sides of the fuse so I know the reversing light switch and fuse are ok.
Still nothing at the tailgate and reversing lights/multi plug.
What or where do I check in between the two points please? 2016 (L405) Autobiography in Black with Ivory - for ULEZ
2014 (L405) VSE in Black with Ivory
2011 (L322) VSE in Black with Ivory
2005 (3.2 V6) Porsche Cayenne in Black with Savanna
1999 (P38) VSE in Burgundy (?) with Sand
Post #418279 17th Dec 2016 2:11pm
160dmb
Ignore - turns out the Chinese Led's have both died and somehow the once the bulb holders are disconnected the multi plugs show live again. Now if I only I knew where the old bulb holders were...........
Can you buy bulb holders alone?
Think I will also fit the bumper mounted extra reversing lights - replacing the rear reflectors and go back to standard rear bulbs unless anyone has any other great ideas. 2016 (L405) Autobiography in Black with Ivory - for ULEZ
Post #418285 17th Dec 2016 2:52pm
