![]() | Home > Technical (L322) > Range Rover 3.6 fault codes |
| will308f Member Since: 19 Apr 2022 Location: plymouth Posts: 603
@ mikey im getting much the same several error codes some relating to fuel pump and fuel pressure sensor ,was going to try the forte cleaner and 2 stroke oil ,just wondering how much 2 stroke oil to use ? thanks mark |
| Adi322 Member Since: 20 Oct 2022 Location: hampshire Posts: 10
Had all of the above and finally changed the sensor on the rail and all th codes disappeared. Finally fixed I thought now a month later same thing all over again. Tried another new sensor but it faults still there. I would be interested to know how much 2 stroke to use as well before I change anything else
| All times are GMT |
