Home > Technical (L322) > Can't open car
Skip720
England 2002 Range Rover HSE 4.4 V8 Oslo Blue
Can't open car
Aaaaarrrgghh I have just gone to clean the interior of my 02 L322 hse but the car will not open, the button on the fob lights as normal but car won't open. I had a punt at fob battery so I replaced it, still the same. Can anybody help. Please
Post #420390 31st Dec 2016 5:41pm
Key ?
Sounds like your car battery may be flat...... happened to me once when the alternator gave up & took the battery with it
Post #420394 31st Dec 2016 5:47pm
mr_spock
Mine does that very occasionally. I believe the sensor is in the driver's A pillar, so hold the key up neat the window and see if that helps. Otherwise it may have gone out of sync. In which case, open the door with the key and resync it. Instructions in the wiki I think.
Post #420400 31st Dec 2016 6:09pm
Skip720
The key just turns in the lock but doesn't open
Post #420403 31st Dec 2016 6:15pm
Skip720
Alistair it's a nearly new battery only been on four months
Post #420405 31st Dec 2016 6:17pm
mr_spock
Ah, that's a problem. Mine did that, but luckily the remote fob worked so I could fix it. Clearly when you get it open you MUST fix the physical locking/unlocking issue!
You could keep trying the remote, but if that doesn't work and the key doesn't work then I'm out of ideas. I expect a car locksmith would have tools that would allow him to open it with the interior handle - I've had it done on my old Porsche 928 - but I wouldn't post details in public.
Ian
Post #420407 31st Dec 2016 6:22pm
Do you have a spare key to try as a remote ?
Post #420409 31st Dec 2016 6:23pm
Skip720
I have a spare key but it has no buttons and just turns like the master. Does anybody know a good car locksmith in Wakefield
Post #420410 31st Dec 2016 6:26pm
Skip720
Thanks guys I appreciate your help
Post #420411 31st Dec 2016 6:28pm
Are you on the AA or RAC ? they can sometimes help ?
Post #420412 31st Dec 2016 6:29pm
Are you sure the car isn't just flat?
In which case you need to get some juice onto it. There are several ways of doing this. If you have a tow socket then you can connect a charger via this and an adapter, I think it is also possible to add juice by connecting a charger to the main feed on the starter as this is direct from the battery, though I would look into that further.
I think it has had the battery drained somehow and hasn't got enough power to activate the locking. There is nothing that can't be fixed with a hammer😜😜
Post #420419 31st Dec 2016 6:46pm
Skip720
I have a tow socket, do you know how I would charge from that?
Post #420421 31st Dec 2016 6:53pm
Do you have twin electrics ?
You need the grey socket
Wiring diagram here - so you can put a meter across 3 & 4 and read the voltage. If needs be, you can also charge the battery using the same 2 terminals
Have a good sniff around the bonnet area first & make sure there isn't a smell of burning. With mine, the alternator diode went - so the battery treats the alternator like a motor - so it burns out & drains the battery completely.....
Post #420423 31st Dec 2016 6:55pm
If as Alistair says the voltage is low across the 3/4 terminals you can make up a cheap adapter using an old 12s plug and some wire and terminal blocks to those terminals in the plug, then connect this to your charger.
Check the voltage first, as it should open with even a pretty dead battery. There is nothing that can't be fixed with a hammer😜😜
Post #420429 31st Dec 2016 7:07pm
Skip720
I only have single socket. Would that be different?
Post #420433 31st Dec 2016 7:14pm
