Home > Off Topic > Monitored Intruder/Burglar Alarm systems
Tim in Scotland
Location: Somewhere between here and there, if not then I'm all at sea or at home in Scotland
2010 Range Rover Vogue TDV8 Stornoway Grey
It looks like after 30 years of crime free living, next leave I will have to consider having a monitored alarm system put into the house, as recommended by the local crime prevention officer after my recent brush with car-key thieves................................. so I'm sure those of you living in the sarf (that is sarf from Scotland not Watford Gap!) must have had some experience of having burglar alarm systems fitted so any advice for somebody with no experience of them?
I have been looking at companies like ADT who do some pretty sophisticated systems that include CCTV that is monitored. So what is necessary, what is window dressing and what is hyped up but not really required? In order to satisfy my insurers the installers also have to be approved so that rules out self installed systems like the (claimed to be excellent) BT wireless system which you self install. I'm looking to cover 2 (one for the house and one for the garage back door) Up and over garage front door, a lean to greenhouse that is built onto the back on my house, one floor to ceiling fully glazed back door/ french window and 5 windows. Are motion sensors still as bad and set off so easily as they used to be? I already have powerful security lights at the back and front of the house but obviously they weren't much of a help this time. I also think that something like a CCTV watching my drive might use useful.
Thoughts please - any companies to steer clear of too! 2018 Mini Countryman Cooper S E All4 PHEV in Melting Silver - it’s whisper quiet in EV and polluter modes
Post #42537 17th Dec 2010 6:05am
this might be worth considering tim, has network monitoring and you can even watch on your iphone..
http://www.maplin.co.uk/Module.aspx?ModuleNo=454337 ... - .- -.
Post #42543 17th Dec 2010 9:06am
igore
England 2002 Range Rover Vogue Td6 Adriatic Blue
Tim give ADT a call and see what they`ve got to suit you. thats who i would go for. oh and they install it Thumbs Up ONE LIFE LIVE IT
Post #42554 17th Dec 2010 10:57am
Pauld
United Kingdom 2004 Range Rover Vogue Td6 Zermatt Silver
I own a hotel and have full a full CCTV system fitted a few years ago by a bunch of cowboys.
We recently had a theft, member of staff helping him self to the safe, with everything recorded onto CCTV.
So we think we have got him and call the police.....
Unfortunately the CCTV footage of much of the theft is not sufficient quality and it is unlikely that a prosecution will result. Bummer.
What ever you go for make sure that the cameras work in both day light and at night, and when they say they do as for some reference sites with the same system and ask the operators. They often have a different opinion, as I have found to my cost.
If I was to start again I would go with some one like ADT or CHUBB. There are many excellent independents who can supply better service etc, but having had my fingers burnt I would go with piece of mind from a "branded" supplier, although this goes against my principles of purchasing from local independents.
Post #42555 17th Dec 2010 11:06am
M44K TS
Noooooooooooooooooooooooooooooooo, don't even think of ADT, they're ridiculously overpriced, their service engineers are half-arsed and the standard of work from what I've seen is horrendous. And that's not just me saying that, I've heard it from a few customers of ADT and even from former ADT employees.
I actually work in the Alarm and CCTV industry, I'm a partner of the family business and we're into our 25th year of trading. We mainly specialise in alarm systems, but also deal with CCTV, door access and electrical work.
We've heard from previous customers of ADT about their annual servicing of systems, we spend between 45mins to an hour checking every single aspect of the system for possible faults, one customer said ADT were in and out in 5 mins and charged 3 times as much as us.
You'll either need a NACOS or SSIAB approved installer, (we're SSAIB by the way) If you get quotes for a system from either, make sure they're installing to grade 2x, that way, it meets the insurance standards. The wirefree system BT offer will be a re-badged version of another manufacturer, usually cheaper quality systems in my experience.
There's basically 2 main types of system you can go for, you have the conventional hard wired system or wirefree, (or a combo of both but I'll explain later)
Wirefree.
Pro's:
No cabling to worry about, less disruption during installation, (no carpets to lift, walls to chase etc) no limitations to where equipment is sited, easy to add extra devices at a later date
Con's:
Most devices are battery powered so will need the batteries changed annually, some systems have battery powered external sounders, some of the cheaper systems require a 'hard wired' sounder, only a handfull of systems meet grade 2 specification.
Hard wired.
Pro's:
No device batteries to change, generally more reliable than wirefree, mainly cheaper to install than wirefree. Manufactures have finally started to think of the aesthetics of the system too, once manufacturer we use for our high end domestic and commercial systems has started to make the remote keypads for the systems in a range of different finishes and the option to surface mount or flush mount the keypad...
http://www.texe.com/document.php?docid=384 (pdf file - the black and gunmetal look very classy when fitted)
Con's:
Longer time needed to install, cabling can't always be hidden, adding extra devices can limited if there is no acces with cables
If I was doing a system design proposal, I wouldn't be quoting for window contacts or inertia shock sensors, basically, for a pretty average run of the mill system, I would advise things like front door to be fitted with a door contact that are on an exit/entry timed zone and PIR's (passive infra red/movement detectors) for the rest of the house as they usually have 90 degrees coverage and up to 15m range, that way the whole room is covered including windows and french doors etc. Plus it saves having cables ran round to each window then fixing devices to the window and door frames.
You'll find you will get very little trouble with any new alarm system be it wirefree or hardwired, PIR's are nowhere near as unreliable as they once were, they're basically fit and forget items now.
For your situation, you could install either of the following, assuming your garage is detached from the house but not too far away.
1, Hard wired system in the house, and another separate hardwired system for the garage
2, 1 Wirefree system for the house and garage combined
3, Hard wired system in the house with a wirefree receiver unit and wirefree devices in the garage. That way you can have everything on one system which would probably work out alot less than both of the above, plus you would only need to set the 1 system.
As for the CCTV, void the likes of a Maplin system, the camera quality might look fine when you're up close to them in the shop, but once fitted, they sometimes haven't got the resolution to produce decent images when it gets dark. Also, some of the IR bullet cameras might sound good on paper with 10-20m IR night vision range, but what people forget is that they're likely to be fitted 4-5m up then angled down, so really, they're pretty pointless, most of the time, it will only light up the reg. plates on your car.
In fairness, the kit linked by Scarey does seem ok, but just to let you know, most of the time, we pay more than that for a decent quality DVR alone from one of our wholesalers, basically, you get what you pay for. A customer of mine wanted his existing CCTV replaced by us as he had bought one of the Makro specials for £400 and was suitably unimpressed by it, (it was Censored though!) If you're only wanting a camera system to cover the driveway, I'd recommend something like a decent low light anti-vandal dome camera, a small 4 channel DVR with a 250GB hard drive. That really should suffice. Most decent vandal domes have a very low lux level capability, the ones we supply and fit go as low as 0.0001 lux with a feature called 'sens up' enabled, basically, it digitally brightens up the image so you can see in almost pitch black.
The majority of DVR's (digital video recorders) now have LAN connection so you can view them remotely, (in fact, I've just been setting one up for a customer today) The only extra thing you will need is a monitor, a standard TFT computer monitor will do the job no problem as long as the DVR has a VGA monitor connection, they it doesn't, you can buy a BNC to VGA converter which will allow you to use a standard monitor.
If you would like any more info, just ask and I'll do my best to offer some guidance. Thumbs Up 2006 Mercedes CLS
1991 Retro-style Mini
But really finding it hard to fight the urge for a S/C...
Post #42620 17th Dec 2010 8:41pm
Andy
We turn out to a lot of ADT activations. They are always graded as an immediate response (10 min) and we always get there well within that time. Yet to catch anyone on premises though- they're in and out in seconds.
I looked into an ADT when we got done last year. The rep explained how it worked. Basically, two PIRs have to trigger for it to register at the ADT control room as a confirmed intruder. One PIR will alert them, but they'll wait for the second one to activate before contacting police. So we know when ADT contact us, it's genuine and every available officer will turn out to it.
In my case, they told me they'd use the existing cables/ power unit/PIRs and just fit a monitor that connects to the police control room. They quoted £500 "fitting", plus a monthly fee for the monitoring of about £25. I thought they replaced the entire system for that money. Quickly told them to do one.
A good mate of mine has a family alarm business and he fitted a monitor that alerts me via my mobile phone. If it were to go off, I'd just dial 999 and tell them I've got a monitored alarm. The police will still (or should) turn out to it as if it were an ADT unit.
Due to spiders in PIRs, power cuts, general faults etc, House alarms falsely go off all the time. It's so common that police won't go to them unless it can be confirmed it's genuine. . When you hear an alarm sounding and wonder why the police aren't coming, remember one thing- that alarm is probably one of many going off at the same time in various parts of your town/city. There aren't enough officers on duty to attend them all. It would be great if there were! 2010 MY Vogue SE TDV8 3.6 Stornoway Grey- fully loaded
Post #42748 19th Dec 2010 1:13am
Seepee
I've got an ADT Redcare 999 system installed at my business and very happy with it,came out best on price when I asked for quotes,serviced twice a year to get around false alarm issues.
As already explained it needs 2 positive alarms from 2 independant sensors e.g. door and PIR before it rings 999 otherwise they just ring me at home .
It has a landline phone link and a mobile backup in case that is cut or faulty.
My engineers are great but clearly that could be a problem elsewhere.
Post #42749 19th Dec 2010 8:57am
letsavit2
United Kingdom 2004 Range Rover Vogue Td6 Java Black
Whatever alarm you buy make sure you get the engineers code for when you need to remove a panel etc for decorating.
I never use mine, i have a bulldog and a baseball bat... Laughing 2004 black Vogue TD6
Post #42764 19th Dec 2010 1:00pm
M44K TS
Redcare & Redcare GSM is fine for commercial systems, but I still say it's overkill for domestic systems, you'd be better off having a digi communicator which essentially does the same job, but is a lot cheaper.
Remember, with Redcare, you have to have the system maintained twice a year plus there's the annual monitoring costs of £400+ depending on which receiving centre is used. Then there's the added ball-ache of having a DD243 dual conformation system installed which is basically double the devices than what you actually need if the insurance companies ask for police response. Personally, I only ever recommend Redcare if it's absolutely necessary and the insurers specifically ask for it. 2006 Mercedes CLS
Post #42765 19th Dec 2010 1:03pm
Tim in Scotland
Thanks for the guidance and advice guys some very useful stuff there. Sorry i haven't replied earlier as I dropped and then stood on my wireless dongle that connected me to the local wireless broadband now have to wait for the next boatload of stores etc that will be delivered to the anchorage before I can get back online on my own laptop.... Big Cry Big Cry Big Cry O2 has also stopped my internet roaming on my iPhone as I have reached the 40 pounds limit imposed under EU regs, so borrowed one of my officers' netbook computers for a few minutes 2018 Mini Countryman Cooper S E All4 PHEV in Melting Silver - it’s whisper quiet in EV and polluter modes
Post #42832 20th Dec 2010 9:35am
bozmandb9
2013 Range Rover Vogue SE TDV8 Causeway Grey
Data limit
Hi Tim, O2 can remove the limit if you ask them to! You may be able to get a roamed data bundle on your Iphone as well. You shouldn't really need a dongle as well, the data plans should be pretty transferrable whether on dongle or phone!
Cheers,
David 2012 SDV8 Vogue SE
Post #42876 20th Dec 2010 5:05pm
