![]() | Home > Maintenance & Mods (L322) > park brake fault |
Baltic Blue Member Since: 13 Aug 2015 Location: North Wales Posts: 3827 ![]() ![]() ![]() |
Check if the wheels are hot.
Harris Member Since: 02 Apr 2013 Location: Northants Posts: 155 ![]() ![]() ![]() |
don't think it is stuck on, wheels cool |
kbald Member Since: 17 Aug 2015 Location: Leeds Posts: 491 ![]() ![]() ![]() |
Was it only the front pads and discs changed?? There is a hand brake reset procedure butthat's normally done whe. You change the rear discs or epb shoes! |
yes only the front, will talk to the garage monday |
47p2 Member Since: 05 Oct 2010 Location: Gone Beyond, Subaru Posts: 8048 ![]() ![]() |
Sounds like a front sensor problem then |
interesting, they replaced one front brake wear sensor, how would that show up as a park brake fault? |
Faulty sensor, poor connection to the loom, badly fitted to name a few |
