Home > Technical (L322) > 2004 Sat Nav Question
Page 1 of 3 123>
comports
Hi Folks - new today. Just bought a 54 plate Vogue TD6 with the sat nav screen (pre touch though) and have seen mention of the upgrade to the Mk IV (DVD) version supporting 7 digit postcode.
Does the earlier version support 4 or 5 digit postcode as I can't find an input for this on mine..?
Will probably have some more questions to follow but getting used to it now. I still have my 2000 V8 Vogue so am fairly familiar with most of the toys already.
Thanks Ash
2022 SDV8 AB
2016 TDV8 VSE
2011 TDV8 VSE
2006 V8 Vogue
2002 2.5 Vogue
Post #42877 20th Dec 2010 5:24pm
daveo
hi, welcome to the forum, your unit is the mk3, cd based the mk4 is dvd based, i have the 2009 map for that and it does 7 digit post code as well as 3d maps, do you have a mk4 unit as yet... V8 facelift Range Rover Autobiography 22" wheels.
Post #42880 20th Dec 2010 5:38pm
comports
Hi Daveo and thanks.
I don't have a source for the MK IV unit yet. Only go the car 4 days ago..!! It's something I would like to look into in the new year but they seem quite expensive from what I've seen.
Do you know if the Mk III support any form of postcode input..?
Thanks Ash
2022 SDV8 AB
2016 TDV8 VSE
2011 TDV8 VSE
2006 V8 Vogue
2002 2.5 Vogue
Post #42882 20th Dec 2010 5:43pm
daveo
hi yes as far as i can remember but i think its only the first 3 V8 facelift Range Rover Autobiography 22" wheels.
Post #42908 20th Dec 2010 8:12pm
Jer
Scotland 2004 Range Rover Vogue 4.4 V8 Atacama Sand
Keep your eye on ebay, the mk4 units are the same as the BMW ones. I got one on ebay with a 2004 DVD for £9.50 plus £7,50 postage. I downloaded the updates from this guys site http://www.myrangerover.co.uk/MyRangeRover/GPSMAPS.html which got rid of the BMW logo and replace it with the 2010 RR one. works a treat as my Mk3 unit was broken and would not eject CD's. Also check out: http://www.bimmernav.net/index.html
Post #43104 21st Dec 2010 8:38pm
MrP
England 2011 Range Rover Autobiography 5.0 SC V8 Santorini Black
Wow that's cheap - when I swapped mine for a MKIV it was over £100 but is one of the best upgrades you can do. I have the 2010 maps + speed cams on mine and it's excellent. "On first name terms with my local Dealer......now."
'61 Plate 5.0SC Autobiography - in Black ——— Gone
'53 plate 4.4V8 Vogue Bonatti Grey inside and out. ----- Gone
Post #43105 21st Dec 2010 8:51pm
daveo
i have the map 2009 and the update disc if any one wants it, i think you would be lucky to pick up a mk4 for under 250 but you never know...if any one has a newer disc then please let me know.. V8 facelift Range Rover Autobiography 22" wheels.
Post #43106 21st Dec 2010 9:13pm
Jer
Must have got lucky, it was not very well listed I did see them for £200 +: http://cgi.ebay.co.uk/ws/eBayISAPI.dll?Vie...K:MEWAX:IT Could not believe I won it for that then could not believe it worked and turned two days later.
I don't think the link I posted to software and map is the latest one as I can't get 3d view or postcode. Anyone have the latest iso file?
Post #43112 21st Dec 2010 10:10pm
dan_uk_1984
Shocked
I paid nearly £400 for mine a couple of years ago!
Post #43120 21st Dec 2010 11:42pm
letsavit2
United Kingdom 2004 Range Rover Vogue Td6 Java Black
Dan, ill give you 9 quid for it........ Laughing
Got look at getting this, my sat nav is crap. So i have got to buy a bmw mk4 dvd nav, thats it yea? 2004 black Vogue TD6
Post #43124 22nd Dec 2010 12:16am
letsavit2
just been looking, cant see cheaper than £380... Sad 2004 black Vogue TD6
Post #43129 22nd Dec 2010 2:33am
@jer...pm sent ... - .- -.
Post #43134 22nd Dec 2010 9:23am
comports
Letsavit - Same here - cheapest was £380. I'll keep an eye out.
I still don't think there is any postcode option on the pre Mk IV (or CD) version. I can't find it anywhere. Ash
2022 SDV8 AB
2016 TDV8 VSE
2011 TDV8 VSE
2006 V8 Vogue
2002 2.5 Vogue
Post #43136 22nd Dec 2010 9:41am
SteveMFr
Site Sponsor
I only paid around €200 (got lucky) - but I searched for a while. You're either going to invest time or money...
Either way it's worth it.
RRC 2Dr, RRC 4Dr,
P38, and 2 L322s
Post #43143 22nd Dec 2010 10:27am
T24RES
If its sat-nav upgrade discs you need try this fella, Mick. http://www.eurosatnav.com/ (Also sells the MKIV laser repair kits)
I've bought discs for the X5 which had speed cam and full post code + a splash screen of your choice. Recently for the FFRR, 2010-11 version, sadly no speed cam on the touch screen version. Very reasonable and freindly service. Recommended Thumbs Up Ian
Post #43160 22nd Dec 2010 11:58am
Page 1 of 3 123>
